Older 7 iron decks
/ Older 7 iron decks #1
jd670
Gold Member
Kentucky
John Deere 3320 - gator cx - JD 425
Will the 4000 and 4000ten series 7 iron mmm decks fit on the 3000twenty series tractors? I had a dealer on Machinefinder tell me the decks are basicly the same, but the attaching parts are different. Told me to get the attaching parts for my tractor and it should fit. Is this true? Has anyone had experience with this? I'm looking at a used 72" deck for my 3320. Wanted to make sure it would work before taking the plunge.
/ Older 7 iron decks #2
As I told you in the other post, I believe that to be 100% correct.
/ Older 7 iron decks #3
I have a deck for a 4510-4710 on my 4310. If anyone on here would know it would be kennyd!
I believe you Kennyd. Didn't mean to make it look like I didn't by posting twice. Thought I was going to be in a position to make a quick decsion, or loose the deal on the deck. Called the dealer that has the deck and it turns out they just got a 7 iron 72" in on trade. It is the correct model that fits my 3320.It has all the attaching parts and pto shaft with it. Going to look at it later this week. I must say, it seems used mmm are gold these days.
/ Older 7 iron decks #5
No problem on this end:thumbsup:
Sounds like you found a good unit. Finding all the attaching hardware to fit a MMM is not an easy or cheap task. It's always better to find one from the same series machine.
MMM's are like loaders, decent ones don't come up often as they are usually kept and sold with the tractor.
Just got back from the JD dealer with my deck. I was quite surprised, it looks almost brand new. They had everything to put it on my tractor except the rockshaft bracket. They couldn't find it. Dealer said they must have used it on another deck. So he ordered me a brand new one and will have it shipped to my house. I'll have to wait a few more days to mount it. Here are some picks..
/ Older 7 iron decks #8
i have a set of larrys mower axels for sale for that deck. if you are interested contact me............bud
Not sure what ,larrys axels are. Do you have pics? Is there somewhere on the JDwebsite I can find a diagram on how everything bolts up to the tractor? Kennyd, I thought I read somewhere that if you have the front 3point hitch and a mmm, you need different front brackets for the mower. I have the front 3pt, is this true? I also have a 60" Land Pride pull behind finish mower,model 2660, that I will be selling if anyone is interested.
/ Older 7 iron decks #10
Larry's Mower Axles are great, I have been using them for about 5 years now on my 60" MMM (he even has pictures on his site of my deck). The deck stores vertical and out of the way when not mounted.
I wish I could help you with the front 3PH/braket question, but I am not that familiar with it. Search JDParts may help, but getting the Install/Owners manual for the deck is probably best.
I found one that may apply, here is the Attachments page for the 3720 and here is the one for the 60" and 72" MMM's.
Hope this is what you need:thumbsup:
/ Older 7 iron decks #11
hi jd670, concerning the mower axels click on to larrys mower axels in kennys answer above and then click on john deere stands in the middle and go to item #45. there are pictures of the axels on my old deck and also on your 7iron deck. i have the front hitch with the 72d mmm. there are two different sets of mounting brackets for the front hitch, one for the 72 7iron and the other for the 72d quick attach mower. they replace the long lift arms held on with the 2 pins on your front hitch. i think nuru had posted pictures of his setup with the 7iron on his 3000 series or find his postings thru one by acolar where he discusses his 366 front blade. hope this helps.......bud
Thanks, that helped alot. Larrys' axels might be the way to go when cutting season is over. I checked my front hitch kit and it came with the correct brackets for the mmm that I have.
/ Older 7 iron decks #13
jd70, glad i could help. contact me if interested in the axel set............bud
/ Older 7 iron decks #14
They get a hundred bucks for two 3/4" tubes, two lawn mower wheels and a swival caster ? I built mine years ago out of spare parts laying around.
Just finished my first time with the mmm. All I can say is WOW this thing cuts. I going to be a happy camper....
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
APPROX (23) 1" X 6" X 12"' & (12) 1" X 6" X 12' (A64281)
APPROX (23) 1" X...
2011 Porsche Panamera Sedan (A61574)
2011 Porsche...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
2011 Ford Fusion Sedan (A61574)
2011 Ford Fusion...
