Need input on brush hog
/ Need input on brush hog #1
wagonguy
western pa
JD 2305
Found a 48" woods brush hog with slip clutch. it does not have a stump jumper. Is that a "must have " option for a BH or based on use? I would use mainly for large weeds/grass-maybe some brush/saplings in the 1-2" size range mixed in. It is in good working cond and price seems good, just wondering if the lack of jumper is a potential pitfall. LMK what you think
/ Need input on brush hog #2
If you hit something too big (stump larger then the cutter can handle), the slip clutch may do what it's designed to do (if it's set properly) or you may stall the tractor.
If you think the cutter is a good deal and it's a good fit for your tractor, I suggest you buy it.
I do suggest you adjust the slip clutch...don't depend on what the previous owner did (or didn't do).
/ Need input on brush hog #3
It's not a "must have"... more like "nice to have", as in, I forgot about that rock or stump. If you have cut an area before and know what to watch out for, it's not as important. A slip clutch is very good to have, make sure it is set correctly.
/ Need input on brush hog #4
Some posters recommend loosening the tension springs on a slip Clutch at the beginning of every season. Engaging the PTO quickly to SLIP the Clutch Disc , thus making sure the Slip Clutch will actually slip when needed.
Others have posted that their Slip clutch have been Rusted / Seized up from setting out in the weather, and it took a bit of work to them freed up to work properly.
thanks for replies. hope to see this tomorrow. from what I have read on TBN , a 4 ft is right size for my 2305. price is +/-$300. that seemed pretty good for a Woods in decent working shape, no holes or busted parts.
most area I would use it on has been cut before by a gravely WB or a tractor w/brush hog. flat ground for most part.
/ Need input on brush hog #6
Could you add a stump plate to this mower? It's not exactly a complicated object. Just a thought. I'm glad to have one on mine as I use it for some really tough terrain.
Here's some ugly guy using a 4ft mower on his 2305. :p
/ Need input on brush hog #7
I had responded to your post (in another thread about cutters (which drifted into "where are Deere CUTs made...")). I wrote about how a small CUT can easily handle a 60" cutter.
Well, for the 2305, I retract that statement. Guess I didn't realize how small and light a 2305 was. More of a subCUT. Probably wouldn't hurt to extend your top link a few turns...
Interesting video, thanks for posting! Try cutting through brush as tall as your ROPS sometime.
/ Need input on brush hog #8
what exactly is a slip clutch?
didn't need a stump jumper on my brush hog w/ my old ford 600. no live pto, so if i hit something, jump on the clutch and the blade would stop before i stalled. now that i have the new 4300....i'll have to adjust my technique. of course, w/ the 4300, i can go at a much more appropriate speed w/ the 3 range tranny...where the ford only had one range. so to keep the engine rpm up, i'd be going quite fast in reverse!
/ Need input on brush hog #9
The slip clutch prevents a sudden shock load from being transmitted to the driving (input) shaft by allowing the input to continue driving but with no output torque to the driven end (i.e. implement).
Bought the brush hog for $275. blades swing free, spindle tight(no play), gearbox and shaft good. could use paint but thatll be later. So I guess I be a-hoggin this summer. HOOOWEEE!!:licking:
/ Need input on brush hog #11
Yes, the 2305 is smack dab in the SubCUT category. I think all of the 2000 series are Sub's. Not sure if the 3000's are too.
What would extending the top link do to help since there is one of those "H" brackets in the mix? I adjusted that thing ad nauseam to find the right spot for lift height vs cut height. I still don't quite understand what these mowers are specifically meant for but I suspect they are intended for flat ground. I don't have any flat ground to speak of so I'm constantly having to adjust the 3PH height to keep the front of the mower from gouging into the ground or being too high to cut. I bought some big casters to try putting on up near the front but haven't taken the plunge yet.
And as for cutting tall brush, I certainly have. I actually made an entirely new path through our woods with this mower and it was a cake walk. I just lift the deck, back over the brush, and slowly let it down. When I move away, there remains a nicely mulched & cleared patch, sort of like Pac-Man.
/ Need input on brush hog #12
You want some play in the top link, I don't even hook up my toplink anymore when mowing (binds up too much). The mower sticks out pretty far and when you drive across uneven terrain, it will let the mower follow the ground better, allowing it to expand and contract on dips and over bumps/hills.
OK Wagonguy... where's the photos? :D
/ Need input on brush hog #13
You may be able to get a stump jumper. All they are is a piece of bent sheet metal that fits between the shaft flare and the bolts securing the flapper blades on the bush hog. Shouldn't be very expensive.
On the other hand, perhaps you can walk your land and determine that you don't have any stumps hidden in the weeds.
The slip clutch should help avoid any major damage if you do hit one. If you hit one with your tractor wheel, it could toss you though.
Ralph
/ Need input on brush hog #14
Raise your lower (draft) links until the side skirts (at the front end) are 2-3 inches off the ground. If your 2305 has some kind of position control (such as a lock or stop on your rock shaft lever), lock it at that position.
Lengthen your upper link until that "U" bracket is loose (the cutter's tail wheel will be on the ground bearing some of the cutter's weight). In use, the tail wheel should always be on the ground.
Try it like that...should work for you.
Where this will not work is where there is an abrupt change from level ground to sloped ground.
There are times I do the same as Teg...unhook the upper link altogether. Not for the whole area I cut, but it is pretty handy if you back up a slope or cross over an abrupt transition as I described above.
/ Need input on brush hog #15
That pretty much sounds like what I am already doing but I have to keep adjusting the 3PH height during use to keep the mower side skirts just above ground as my land is very uneven, not like a nice flat pasture.
The only position control or position lock on the 2305 is my right elbow.
Maybe I'll try dropping the upper link but I'm concerned about not being to pick the deck up quickly if I come across a rock or big stump. I would also lose the ability to "Pac-man" my way through dense brush (vertical bites).
Thanks for your input. Hopefully Wagonguy is soaking all of this up for his upcoming work.
/ Need input on brush hog #16
I have a 2320 and just purchased a 48" frontier rotary cutter saturday, Paid $1200 dollars for it, but I had to put it together (which is no big job) Since they are shipped with no oil in the gearbox, I am debating on filling it with synthetic gear oil, hoping that it will let it run cooler. I figured a 5 footer might be a little large for the tractor. I haven't put it on yet but will let you know how it works out:D This also has slip clutch and chain guards!:thumbsup:
/ Need input on brush hog #17
$1200 for a 48" cutter???
And you had to do the finish assembly???
Man, that's a lot of money for a 48" cutter!
/ Need input on brush hog #18
yes that sounds like a lot of money... but we started at $1550.00 plus tax. I checked into a tractor supply model and a kodiak also. Yep they cost a little less, but neither one had any chain guards or slip clutch.....So by the time I got done comparing apples to apples there wasn't much difference in price, plus if I want any parts I know I will be able to get them ASAP. With my kodiak dealer it might take a while same with our Tractor Supply store (they just opened here 2 weeks ago) Besides I like green!
/ Need input on brush hog #19
There is an old saying, you get what you pay for ! At least you know you have a quality product, and parts available.
/ Need input on brush hog #20
As long as you're happy, we're happy for ya
