Jack for tractor?
/ Jack for tractor? #1
Royboy
Member
I have a Kubota B2410, a compact tractor... not big, but not small either.
Does anyone know of a jack (preferably hydraulic) that would be suitable for lifting the rear wheels of a tractor that size, but that might also be suitable for cars and pickups?
Thanks!
/ Jack for tractor? #2
My tractor weighs 3600-lbs (+filled rear tires) and I use a 3-ton floor jack. Works fine.
/ Jack for tractor? #3
My JD 4600 weighs in at 5,450 w/tires filled. My F-350 is about the same and I also have a 3 ton jack, works just fine. Good Luck :thumbsup:
/ Jack for tractor? #5
Same here and I always position the jack under the drawbar bracket.
/ Jack for tractor? #6
Your B isn't too far different in weight from my 4010, about 2200 # with the FEL. I just use one of my floor jacks either under the drawbar (to lift the whole rear) or to each side to lift one wheel (have to remove one to get to the hydraulic filter). It's the same jack (from any of the big box stores) that I use to lift corners of my cars or pickup (heaviear is the pickup at 3500 #).
Ralph
/ Jack for tractor? #7
Thanks!
Here is a hydraulic jack that works just fine. A bit pricey however.
/ Jack for tractor?
When you folks use a floor jack or bottle jack to raise one or both of the back wheels do you use jack stands when working or do you find that things are stable and safe enough with just the jack?
Thanks
/ Jack for tractor? #10
I use jack stands to hold it in place. Everyone should use something besides the jack.
/ Jack for tractor? #11
You can also build a simple 3pt tractor jack patterned from the old Ferguson 3pt jack... see the attached picture.
With it you can lift the back or back and front of a tractor using only the 3pt...KennyV
/ Jack for tractor? #13
Good point!!!
I use 'em too and I should have noted that in my post.
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
