Tires what tires are these?
/ what tires are these? #1
big e
outside columbus, ohio
L3130 Kubota
Hi. This is my first post and my first season of snow plowing. I have a 1/2 mile long driveway with two steep icy hills and my L3130 with FEL does not have filled tires or wheel weights. After sliding frontwards, backwards, and sideways down the hills I decided to get fresh underwear and consider tire chains. From reading posts here I guess I'd get rear chains.
Questions:
1 - What chains are best for blading snow on icy gravel roads? Should I get something like the V-bar duo or Double Chains? I don't foresee being on any pavement.
2 - Does salt harm gravel roads? What kind of salt is cheapest. I'd just apply it by hand or hand spreader in the worst curvy hill spots.
3 - In trying to determine proper chain size, I did a search and tirechain says my size tires (420/70-24) have two different kind of treads. Tirechain.com says:
420/70-24
NORMAL NHS TRACTOR TREAD ONLY
and
FOR INDUSTRIAL TREAD GO TO:
420-70R-24
Which are mine??
Heres a photo of my tires... can you ID?
and
a photo of one of the offending hills (the curve makes it worse.)
and
a photo of why I don't want my tractor rolling.
I might try to wait out this winter and attempt to score some used chains in the off season but I'm running out of underwear.
Thanks in advance. This website is a great resource.
/ what tires are these? #2
You have industrial tires (R-4's). You'll want to clean off the sidewalls and see which brand and size tire you have before you order chains.
Rather then order online, perhaps you should call Tirechains.com and tell them the brand and size.
Added: NHS is Non-Highway Service (learned something new today!). I'd guess your tires are "NORMAL NHS TRACTOR TREAD ONLY ". This should be embossed on the sidewall of your tires, so check before ordering.
During my search, it took me to tirechains.com and there was one picture (NHS tread) that look identical to yours.
/ what tires are these? #3
big e, is that a watercraft registration decal on your tractor?? You take it fishing too?? Or maybe ice fishing?? :)
/ what tires are these? #4
Thanks for the info and the tire ID. I thought they were industrial tires but the "NHS" listing baffled me.
and
Yes, thats a watercraft registration... good eye! I mow/hog on the pond levy so if I go in I'd want to be IN COMPLIANCE! Actually, it came off my canoe when I renewed the registration.
/ what tires are these? #6
There's a thread here about chains on industrial tires.
http://www.tractorbynet.com/forums/owning-operating/159205-tire-chains-industrial-tires.html
At a minimum get chains on the rear. If you can swing it, get chains on all 4, you'll be glad you did. I have standard 2 link chains on my R4s and they work great. http://www.tractorbynet.com/forums/owning-operating/159205-tire-chains-industrial-tires.html
I second that. I bought my chains on line and ordered wrong size (for R1 tires I suppose.) so they are about two cross links shorter. Since I needed them right away I put them on. They work great even with missing links.
/ what tires are these? #7
always load the rear tires on a tractor, you need that weight for traction and stability on hills. since you have those useless industrial tires the best thing you can do is put chains on them, front and rear, but without the loaded tires it won't help much.
/ what tires are these? #8
Everyone is right, a little or a lot of ballast on the rear of the tractor goes a long ways to regain some traction and balance front to rear. Could be some kind of liquid in the rear tires and or a heavy weight on the rear. Doing that some kind of chains on the rear would do wonders. Obviously more cross bars are better, but if it not ice anything would work. It take all these things to make a stable tractor that has traction in snow and ice, not just one thing.
/ what tires are these? #9
They are R4's and the best thing you can do with the current tires is fill them then think about chains.
Chris
/ what tires are these? #10
I am in the same boat that you are. I have a 2.5 mile driveway up over a mountain and the R-4 tires really suck in the snow. My tires are not loaded either , I just bought the tractor. It is pretty helpless for sure.
As far as the salt thing on gravel/dirt roads goes, I was always told not to use salt or you will have a muddy mess. It is said to " take the bottom out" of your road. I tried salt on a short stretch once and it did make that section a total mess for quite a while... I wouldn't do it if i were you. If you have a wood/coal stove or know someone that does, ashes work great on the icy spots and it will not harm your road come spring.
/ what tires are these? #11
never put salt on gravel or dirt roads, you'll be sorry, makes the ground spongey and the bottom will drop out of it.
Good advise with the salt.
Next winter I'll be "more" ready. Aggressive chains, weight in rear, pile of sand, fresh undies.
And if that doesn't solve it, would paving the very worst 60 foot stretch help?
/ what tires are these? #13
lot of controversy about chaining fronts as well as rears. I, too, have icy steep hilly driveway and find front chains essential along with rears...reasons: ability to steer; and, ability to have front wheel braking (in 4wd).
An interesting side note: I have a 4330 with wide turfs and an 84" rear blower, which just covers my tires. This year I picked up an 8ft. meyer plow blade and fitted it to a QA for my loader...seemed like a good idea, not! In the two big snows (30" or so, each) I used the blower, but found that unless I raised the plow blade uncomfortably high, it was bringing snow back down into the blown path...even angled it was too wide...If I had plowed continually with the storms I could have used the blade, but it is just incompatible with the blower...had to drop it and change back to the bucket. Oh well, live and learn
/ what tires are these? #15
Big e, you also want to check and see what type of clearance you have between the tire and your rear fenders. Some of the Kubota's with R4 tires have a problem fitting chains do to the clearance issue. I don't know if that is a problem with you L3130 or not.
MarkV
You have to register a canoe?
Gaday. In Ohio, yep. Register, not title. Bigger "boats" get titles. But I think only if you plan to put it in public/state waters. I only have plans to use it on my pond, so I'll probably let it expire in 3 years. One reason I registered it to begin with so it was on record with the state so if some loser steals it maybe there'd be a way to trace it back to me.
/ what tires are these? #17
MarkV
Kubota sells wheel spacers to gain some extra clearance. I think it cost about $200 CDN for spacers for an L3400 (for reference). I would go with 4 wheel chains!
/ what tires are these? #18
Heaven's above!. And I thought our Government was intrusive enough. How about floaties and paddle boards. You have to register those too?
/ what tires are these? #19
In Indiana you have to register anything that has a motor, even a electric trolling motor.
Sorry for getting off topic.
Chris
/ what tires are these? #20
Here in Canada we now need a license to operate any powered watercraft.
And that includes the smallest electric trolling motor.
All this came about because of the pesky jet-boats that buzzed swimmers at the beaches.
Naturally one needs to take a training course to write the exam at cost of $80.
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2015 Hitachi ZX210LC Hydraulic Excavator (A61572)
2015 Hitachi...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2018 FREIGHTLINER...
SET OF UNVERFERTH LIFT ASSIST WHEELS & REACH ARMS (A63291)
SET OF UNVERFERTH...
