Comparison Mahindra or Kioti?
/ Mahindra or Kioti? #1
Hummer H1
Mid-Atlantic
JD's
I want a heavy tractor(for good traction), powerful, 50hp or so, 4wd with FEL. I will be moving snow with FEL and rear blade, maintaining a gravel road (about half mile), FEL work, using a rotary cutter, etc...
I want to try either a Mahindra or a Kioti. I have never owned either brand but I have heard good things about both. I would like a comfortable operators station (no cab), I am 6'5". I do my own regular maintenance. I have dealers for both brands close enough.
Which one should I buy and what model? Thanks:)
/ Mahindra or Kioti? #2
They are both great tractors. I would take a good hard look at both. I would probably get the one that fit me the best. Sit in the seat of each and get a feel for all of the controls. How they are placed and if that fits you. Double check the specs of each one, I would guess that they are pretty close. Mahindra just came out with a 5035, it looks to be a very nice machine, but then I am a little partial, I have 2 Mahindras. Double check what options are available, they are usually less money if purchased at the same time as the tractor. So if you think that there is even a chance that you might need or want any of those options, best to get them with the tractor purchase. A lot of times, you can also get great deals on implements at this time also.
Do a lot of research, ask a lot of questions.
Good luck
/ Mahindra or Kioti? #3
Maybe you could get the dealers to let you bring them to your house and run 'em for a few hrs to see what you think.
These are both well respected names and you prolly wouldn't go wrong either way.
/ Mahindra or Kioti? #5
When I looked in the 60-70 range and ended up buying the 7520, I dont remember why I eliminated Kioti. I think it was either less hydraulic delivery or smaller front tires or no 2 speed pto. The 7520 had everthing and nobody else in the price range did.
Happy shopping!
larry
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
(8) 2" Rachet Straps (A62183)
(8) 2" Rachet...
John Deere 6125R (A60462)
John Deere 6125R...
2019 Case-IH Maxxum 150 (A62180)
2019 Case-IH...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
Jumper Cables (A62183)
