Silo blower converted to leaf blower
/ Silo blower converted to leaf blower #1
shawn1533
Member
Butler PA
MF 1533
After reading several threads I decided to purchase a used Gehl Model 87 silo/forage blower to convert to a 3 point leaf/debris blower. Does anyone have any suggestions, lessons learned, or pictures of a similar conversion they could share? I will post progress pictures of my build when I begin.
/ Silo blower converted to leaf blower #2
That would be a monster blower! Good luck!
/ Silo blower converted to leaf blower #3
I've just built a pto leaf blower for my Mitts 160.I used a old furnace blower,a simple angle iron mount and a shaft I fabbed.It works great,with my 3 speed pto I'm spinning it a little faster then the motor that was with it.I put a small sheet metal shoot to aim the air flow down a little and to the back.The leaves on my road get shot about 20 feet back in the bush,were they belong.I put 6 inch legs on it with quick pins,so it stands off the ground when I remove it from the 3point hitch and some 1/4" screen over the openings to keep the leaves out from the wheel.I've tried to post pic's on this site but can't figure it out,I have posted pic's on yahoos Mitsubishi tractors group,look for Sam's Mitts in muskoka .Build one you will love it ,beats rakeing.
/ Silo blower converted to leaf blower #4
That's what I had been planning on doing. Only problem is I need to get the blower first. I'd love to see the picts but haven't yet figured out how to view them.
I spent over an hour outside this afternoon blowing the leaves off my driveway before the rain. I'm tired of it and so are my shoulders!
Maybe I'll make that my winter project!
Keith
/ Silo blower converted to leaf blower #5
I found a slightly used blower at a local equipment dealer for $300 including all the piping for the silo.
I did try the blower as is to verify the operation and force of the fan. It ran surprisingly quite. The blower was making leaves 30+ feet in the tree shake and tremble.
I will be starting the build tonight by removing the feed auger and rotating the exhaust port 90 degrees. I will then cut a more centralized intake hole and weld in a patch over the existing auger intake to the blower. I will then make attachment points on the blower for the 3 point hitch.
Stoweski,
That is exactly why I decided to pull the trigger on the build. Although I have a good back pack blower, my back, knees, and just about everything hurts after cleaning up oak leafs for hours starting in October and ending sometimes around Easter if the snow comes too early.
Srjones;
Thank you for the link. I have read a lot of threads and seen a couple references to similar set-ups but no pictures or descriptions.
/ Silo blower converted to leaf blower #7
Where do you blow them to?
Maybe the neighbors lawn. (grin)
/ Silo blower converted to leaf blower #8
Shawn, thanks for posting. I have been thinking about this too, for leaf blowing AND for stump pile fire accelerating. Of course I'd use several lengths of silo tube to get back from the blast furnace.
Can I ask how much horespower you have to spin the Gehl blower? I assume it is a 540 pto attachment, correct? I know we used 120 hp diesel tractor working at full power to fill silo, but you and I are going to move only air here, so the power requirements must be much less, don't you think?
Keep us posted, please.
/ Silo blower converted to leaf blower #9
You should be able to work it up with 20 horsepower and a hydro would make it good for small adjustments for optimum performance.
Although that blower is not that big compared to the new farm silo blowers for moving leaves it's going to be about as good as it can get!
For maximum performance settings we used to do pass a dime and toss a nickel!
/ Silo blower converted to leaf blower #11
to make the "more centralized intake" what about just drilling a lot of 1/3" or 1/2 " holes to keep unwanted stuff from being sucked in
BTW it will also help to get a burn pile going real well and cut the smoke volume too!
tom
I am also curious about the pass a dime and toss a nickel test.
Jimgerken:
I am using a 33 HP Massey. I am sure I have more than enough power.
Tommu56:
That drilled holes is a great idea. This will allow me to optimize the intake size and avoid the extra cost of a protective screen.
/ Silo blower converted to leaf blower #13
I'm not art, but I think I can explain the dime / nickel thing...
If the blower vanes will pass a dime (dimes thickness of clearance) and toss a nickel (not enough clearance for a nickel) you should have a pretty good fit.
Dunno if the nickel being plugged would make a difference tho... :p
/ Silo blower converted to leaf blower #14
Yes . . Clearance between band and tip of blower blade.
I'm wondering how this would work as a truck loader. Slide the band back to silo position add the silo pipe/chute.
Make a hose connection where the hopper inlet used to be and suck/blow leaves "till the cows come home."
/ Silo blower converted to leaf blower #15
I helped a friend build one of these with a cotton picker blower. he used it to vacuum them and also blowing and for brush piles. It works great for wet brush.
/ Silo blower converted to leaf blower #16
Wondering how you did with this project. Pics would be great!
/ Silo blower converted to leaf blower #17
i would use expanded metal grate instead of drilled holes, faster to do, more air flow, cheaper.:thumbsup:
/ Silo blower converted to leaf blower #18
Good Job!!!!
/ Silo blower converted to leaf blower #19
Just wondering if anyone has any ideas about pully sizes to use with 540? i got mine built and now it wont blow leaves very well. I dont think its over spinning it, i dont think i got enough speed. I got a 12" pull on the pto side(540 pto) and a 4" on the fan. So i figured it should be turning it 1-3 and at pto speed should give me about 1500 rpm(aprox). I built a duct to dirrect air but it didnt seem to help much. Any input would help as im lost now.
/ Silo blower converted to leaf blower #20
I just purchased a used walk behind 5hp leaf blower as I have a ton of oak leaves. I am very curious to how this turns out. I hope to see a lot of pictures.:thumbsup:
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
MASSEY FERGUSON 2605 TRACTOR (A64276)
MASSEY FERGUSON...
46" X 51" TRUCK BED SEAT PLATFORM (A64280)
46" X 51" TRUCK...
2018 International LT Automatic Day Cab (A62613)
2018 International...
Caterpillar E120B Excavator Service and Parts Manuals (A63117)
Caterpillar E120B...
2019 International DuraStar 4300 26ft. Reefer Box Truck (A61573)
2019 International...
