>> LOADER QUESTION ??
/ >> LOADER QUESTION ?? #1
BearKiller
I am not sure just where my question fits, so I put it here.
Wherever there is a pivot point on my loader, there is quite a bit of "slop" in the side-to-side fit of things.
For instance, the cylinders can slide back and forth about an inch in their brackets.
At the bucket, the cylinders have about two inches of side-to-side play.
I am thinking of cutting some pipe/tube to slip over the pins and take away this slop, making two of these spacers at each pivot point, thus centering the cylinders, etc.
Is this a good idea ??; or, should I leave the "slop" ??
Thanks.:)
/ >> LOADER QUESTION ?? #2
2 inches sound excessive. All the pin points on my FEL have about an 1/8" of "slop" which I dont have or see a problem with. If I had more than that, I would shim it up. I would suggest contacting your dealer to look at a similar model and compare. It sounds like someone may have replaced the cylinders or maybe the original dealer put the wrong cylinder on where you have the 2 inch slop.
Anything is possible, as it is a 1972 model.
I am going to split the differences and shim on both sides of each connection point and aim for = or - 1/16" slop and that should tighten things up nicely.
On closer examination, there is a definite difference in the two mast cylinders, so I figure one, and probably both, have been replaced at different times.
It may not even be the original bucket.
Thanks.:)
/ >> LOADER QUESTION ?? #4
Does it have the right sized pins or are they worn??
/ >> LOADER QUESTION ?? #5
Cut out some washers from a 1/2 rubber mat, that will take out the slop, and give you some side play.
You are a genius !!!
I happen to have miles and miles of conveyor belt that I scavenged from the quarry that would fit the ticket fine.
Come to think of it, I have plenty of various thickness bias tires that I can cut plugs from the sidewalls and save my belt for something else.
I even have a genuine tire "plug-cutter" that cuts an inch diameter plug through a tire; it's real intention is to cut a perfect hole for a big plug-patch to pull through.
Thanks for starting my head in the right direction.:cool:
Thanks.
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2002 WACKER RD25 ROLLER (A59906)
2002 WACKER RD25...
