To grease or not to grease, that is the question!
   / To grease or not to grease, that is the question!
@HawkinsHollow
Maybe you can be the test case. You said you have 2 pivots. Grease one. Don't grease the other. Monitor them and report your findings back here. So you ruin one of the pivots. It will be worth it to solve the debate. :)
Seems like a worthy cause. But honestly most of y'all will be dead by the time I use this thing long enough to wear anything out.
Question. Do they make the pins out of a lesser material so the pin wears out before the implement? Just thought of that and it seems like a good ideea.
   / To grease or not to grease, that is the question! #14
I would grease it for sure. Then I would grease the pins that get direct contact with grease more often, but then again, it's only 3 pins so I would most likely end up over grease the 3 pins more often. šŸ˜…
   / To grease or not to grease, that is the question! #15
At 100hrs that pin joint on mine started to wear considerably. I drilled and tapped a grease fitting for it. Pulling it apart to grease the pin didn't seem like a long term option. I noticed the other end wearing also, but already had a fitting for it, one that I was failing to grease. As far as dirt getting to it, I wonder. The front end loader joints for the quick disconnect are right down there in the dirt also, and they get greased.
2008 International 4300 Water Truck, VIN # 1HTMMAAN58J687362 (A57453)
2008 International...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
2020 FREIGHTLINER PT126SLP TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2006 APPA TL (A55787)
