To grease or not to grease, that is the question!
   / To grease or not to grease, that is the question!
@HawkinsHollow
Maybe you can be the test case. You said you have 2 pivots. Grease one. Don't grease the other. Monitor them and report your findings back here. So you ruin one of the pivots. It will be worth it to solve the debate. :)
Seems like a worthy cause. But honestly most of y'all will be dead by the time I use this thing long enough to wear anything out.
Question. Do they make the pins out of a lesser material so the pin wears out before the implement? Just thought of that and it seems like a good ideea.
   / To grease or not to grease, that is the question! #14
I would grease it for sure. Then I would grease the pins that get direct contact with grease more often, but then again, it's only 3 pins so I would most likely end up over grease the 3 pins more often. šŸ˜…
   / To grease or not to grease, that is the question! #15
At 100hrs that pin joint on mine started to wear considerably. I drilled and tapped a grease fitting for it. Pulling it apart to grease the pin didn't seem like a long term option. I noticed the other end wearing also, but already had a fitting for it, one that I was failing to grease. As far as dirt getting to it, I wonder. The front end loader joints for the quick disconnect are right down there in the dirt also, and they get greased.
Mccormick Hammer Mill (A57454)
Mccormick Hammer...
2007 John Deere 6215 (A57148)
2007 John Deere...
1998 Mazda B2500 (A57148)
1998 Mazda B2500...
2012 PETERBILT 388 (A58214)
2012 PETERBILT 388...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAHP71W77X101435 (A57453)
2007 Ford Crown...
2353 (A58376)
2353 (A58376)
