>> LOADER QUESTION ??
   / >> LOADER QUESTION ?? #1
BearKiller
I am not sure just where my question fits, so I put it here.
Wherever there is a pivot point on my loader, there is quite a bit of "slop" in the side-to-side fit of things.
For instance, the cylinders can slide back and forth about an inch in their brackets.
At the bucket, the cylinders have about two inches of side-to-side play.
I am thinking of cutting some pipe/tube to slip over the pins and take away this slop, making two of these spacers at each pivot point, thus centering the cylinders, etc.
Is this a good idea ??; or, should I leave the "slop" ??
Thanks.:)
   / >> LOADER QUESTION ?? #2
2 inches sound excessive. All the pin points on my FEL have about an 1/8" of "slop" which I dont have or see a problem with. If I had more than that, I would shim it up. I would suggest contacting your dealer to look at a similar model and compare. It sounds like someone may have replaced the cylinders or maybe the original dealer put the wrong cylinder on where you have the 2 inch slop.
Anything is possible, as it is a 1972 model.
I am going to split the differences and shim on both sides of each connection point and aim for = or - 1/16" slop and that should tighten things up nicely.
On closer examination, there is a definite difference in the two mast cylinders, so I figure one, and probably both, have been replaced at different times.
It may not even be the original bucket.
Thanks.:)
   / >> LOADER QUESTION ?? #4
Does it have the right sized pins or are they worn??
   / >> LOADER QUESTION ?? #5
Cut out some washers from a 1/2 rubber mat, that will take out the slop, and give you some side play.
You are a genius !!!
I happen to have miles and miles of conveyor belt that I scavenged from the quarry that would fit the ticket fine.
Come to think of it, I have plenty of various thickness bias tires that I can cut plugs from the sidewalls and save my belt for something else.
I even have a genuine tire "plug-cutter" that cuts an inch diameter plug through a tire; it's real intention is to cut a perfect hole for a big plug-patch to pull through.
Thanks for starting my head in the right direction.:cool:
Thanks.
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
208320 (A58375)
208320 (A58375)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
Bobcat A770 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
