Lug nutz
/ Lug nutz #3
If its a 5 lug wheel and has standard egg corn 1/2" lugs the recommended value is 110-120 Ft Lbs. But like builder said, check your trailers literature or call the manufacture.
Chris
/ Lug nutz #4
Does anybody actually use a torque wrench on lug nuts ?
The only time I pull my torque wrench out is for head bolts, everything else is by the grunt system.
/ Lug nutz #5
I do on all the trailers I pull, which is as many as 75 different ones per year. I have been bitten. It actually lives in my truck with a 6 ton bottle jack and a 4 way lug wrench. For the torque wrench I bought a set of flip flop lug nut sockets from Harbor Freight.
Chris
/ Lug nutz #7
Have to agree with Willl on this one.. All my years as a mechanic from heavy line ending up in drivability.. I only used a torque wrench on heads, mains and rod caps. and to check pinion bearing load (inch pound torque). And I never had a wheel fall off or any other major malfunction.. Maybe a few more when I first started but once your familiar with your tools etc. you really dont have time while working on comission..
If ya wanna take it to limit and get technical there is probablly torque specs for headlight ring.. If you have to desire to torque them ;)
/ Lug nutz #8
As the old saying goes, "Do as I say, not as I do.":D Like Willl, I've never used a torque wrench on lug nuts, but I also know that DiamondPilot and Builder are right. You ought to use one.
/ Lug nutz #9
I think it is getting more and more important. I can not tell you how many complete wheels come off along the highway I live 1.5 miles from. I bet I see one a week and it usually seems to be the front drivers side. Not sure why but on the left side things are always trying to loosen themselves.
I have a feeling it has to do with the new light weight aluminum and other material wheels. They are making them lighter to improve the ride and they are getting bigger at the same time. Larger leads to more loads. Heck you are seeing 18" wheels with only 4 lugs on cars like Civics from the factory.
This thread made me think the other day about my lugs. I put new front brakes on my Saturn a month back and torqued them to spec, 96 FT LB, I did 100. Anyway I ran the wrench around them again and gave 5 of the 8 total front lugs a half a turn or so. I attribute this to the new rotors I had put on but either way they were slightly loose. I do know when I go to my tire store now days they always use a torque wrench and then give you a paper with all the specs, including torque, and recommend you bring it back in 200 miles or less for a re-torque.
Chris
/ Lug nutz #10
That's only for the lawyers. :rolleyes:
/ Lug nutz #12
I have a neighbor who lost his compact 2005 Chevrolet sedan last year when a wheel came off an 18-wheeler and hit his car hard enough to total it. And it was a miracle he wasn't injured. I'm not sure how many miles he had on it, but I was surprised to learn it was a 2005 model because I had thought it was almost new just from seeing it parked in his driveway.
/ Lug nutz #14
Driving on the hiway from Toronto to Montreal, a ten wheeler lost a left rear wheel which ran parallel to the truck, turned towards my lane, jumped the median and came straight at me!
Fortunately it hit a bump and cleared my hood by just enough to sail over the car!
With the speeds, velocity and angles you just don't know if to brake hard, swerve or accelerate.
I did, however make the best of the situation.
Stopped, backed up and loaded the tire/rim in my trunk and sold it at the next gas station.
Took me some time to stop shaking.
The truck never even stopped or slowed down.
/ Lug nutz #15
Actually Ontario made some laws a few years ago over this subject making the person responsible for tightening the fasteners responsible. They have backed off some but it was all over the ttrucking industry publications when it happened.
Torque sticks are good for production shops.
The biggest problem is no one goes back in 200 miles for the re-check!
/ Lug nutz #16
I do, and like I said I found loose lugs on the front of my Saturn last weekend. I will admit I had forgotten, but this thread made me take 10 minutes and go around and hit both trailers, and all 4 vehicles.
Chris
/ Lug nutz #17
That's quite a statement.
Willl,
I don't want to come across as being arguementative with you, but I know a lot of cops, wrecking company owners & truckers. They tell me many accidents are caused by tire/wheel combinations flying off and striking cars.
Just trying to emphasize the importance of the torque wrench.
Which brings to mind the question-why not just do it and be safe? :confused:
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A69167)
2016 INTERNATIONAL...
JOHN DEERR 850K LGP (A67714)
JOHN DEERR 850K...
Shop Cart (A68134)
Shop Cart (A68134)
PALLET OF TOOLS (A67714)
PALLET OF TOOLS...
2006 Stephens Aluminum 407 T/A Chemical Tanker Trailer (A68183)
2006 Stephens...
