Sloppy Hydroback
/ Sloppy Hydroback #1
SnowRidge
Elite Member
East Tennessee
Power Trac PT-425 / Branson 3520
Does anyone with an older PT with the hydroback feel their treadle is sloppy? I have almost one inch of dead movement measured at the end of the right hand treadle on my PT-425, which feels excessive. I just don't remember how much there was when the machine was new.
All of the motion appears to be transferring to the hydroback cable properly, but not to the output shaft of the hydroback. Has anyone disassembled their hydroback or had to replace it?
/ Sloppy Hydroback #2
Yes. I have torn down the Hydroback and cleaned everything, and put it back together and adjusted to Terry's advise, but it is still not right. There are pictures in an earlier post of mine. Basically what it is, is a spring within a spring, in a housing, that is supposed to center the pedal. A new cable for the Hydroback runs about $125.00. It is probably cheaper elsewhere.
There is some adjustment up by the pedal for the cable.
Do a search on Hydroback on this forum.
/ Sloppy Hydroback
How is the cable terminated inside the hydroback? One of your posts alluded to it being loose. I did not see any pictures. I'll search again.
Edit: Found the pictures. I assume the end of the cable is threaded into the hydroback. Is there a lock nut involved?
/ Sloppy Hydroback #4
Haven't noticed any play in mine at all (2001 model year). If you barely touch the treadle in either direction, the machine moves.
/ Sloppy Hydroback #5
Mine works the same as Moss's. I have a 2002 PT422.
/ Sloppy Hydroback #6
I can't remember, I tried searching for my pictures, but could not find them. I am thinking it is a nut tighten down on a nut. At the present time, I can go faster in reverse because of that cable, or something else.
/ Sloppy Hydroback
Thanks, everyone. It sounds like my cable is loose inside the hydroback. I will have to take it apart. I just hope it holds together until I can get to it.
/ Sloppy Hydroback #8
There is a nut on the cable housing that needs to show a certain of threads. If you take the Hydroback apart and clean and lube it, call Terry and he will tell you the correct number of threads. for the adjustment.
/ Sloppy Hydroback
Good to know that. Thanks, J_J.
/ Sloppy Hydroback #10
You probably have already done so, but if not, check the two bolts connecting the right and left treadles to the center section. Mine got very sloppy once and I found those bolts very loose.
2014 FORD F350 SUPER DUTY PICKUP (A60736)
2014 FORD F350...
2025 Pabreak 80in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2003 FREIGHTLINER FL70 DAY CAB (A60736)
2003 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Dexter trailer axles (A61567)
Dexter trailer...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
