Splitting Rock
   / Splitting Rock #51
Geneolgy research gas since revealed that my great-great Grandfather was a Stone Mason, so it is in my genes and I truly feel sometimes that he is helping me out when I ask and stones just seem to fit in place. Call it what you want. This is my 3rd wall before nI found our that my GG Grandfather was a stone mason. It is truly hard work and I wouldn't wan't to make a living at it.
Great, any chance that I could get you and your GG Grandfather to come over and help me with mine. The wife is useless. I have to use my tractor and straps to put the rocks in place, then a 10' digging bar to move them. If it falls over this winter, I am making a burial mound with them.
Most of the rocks are not huge, but some are 3-4' long, about 2-3 foot deep, and about a foot or so high. SOme are twice that size, and others are for shims. Would appreciate the help, and I would happily buy the beer of your choosing.
   / Splitting Rock #53
I saw an episode of "Cool Tools" on the DIY channel this past weekend that featured a product made from bentonite clay that is used to split rocks. It still requires drilling a hole in the rock, you mix the product into a slurry and pour in the hole, takes and hour or so to fracture the rock. Was looking for a link to the product but couldn't find it, if I do I will post it.
   / Splitting Rock #54
I believe that DIY has the link to that product. I looked it up after I saw the episode. Nice idea but to me that product was a tad bit expensive
   / Splitting Rock #57
I just got a price on that eze break unit. It's 1600 without any loads. I'd like to find a rental place and try it out.
Matt T.:D
   / Splitting Rock #59
I've several (10 to 20) large granite boulders to split ranging in size from lawn tractor to Volkswagen size that need splitting. Based on this thread and You Tube videos am I correct in thinking that I can split them with an electric drill and feather/wedges? It appears that one poster, Gunnahafta, was doing it with 12v battery drill and a ï½½ core bit. I have a Hilti 14v high torque hammer drill and a Milwaukee ï½½ heavy duty right-angle drill. The Milwaukee is not a hammer drill.
1. Would either of these work with a diamond core bit?
2. Should I stick with my hammer drill and a regular stone/masonry bit?
3. What size feather/wedges are recommended?
I realize that if this will work it will be a LOT of Work. That part doesn稚 faze me. A year or two ago I cut down nine eucalyptus trees (some over 80 tall) sectioned them into rounds (some close to 3 in diameter) and split all of it by hand with a Chopper1 Axe. My only concern is can I split the boulders with one of my drills and feather/wedges?
   / Splitting Rock #60
Having spent many hours splitting rock with different methods let me chime it. I ended up with several rocks bigger then my truck that the excavator couldn't move. I'm always on a budget and asked everyone. I got advice from starting a fire around it to blasting. None were an option. I tried the feather/wedges and they do work but some times you drill for an hour, Put them in , tap , tap tap and all it does is break off the top 4" sideways unless you have a good vaine in the rock. Here is how I ended up.
Get a large Hammer Drill. I have a TE92 Hilti bought it off ebay $100. or any hammer drill that will take SDS max bit. Buy a box of Dexpan off ebay for like $100. It comes with 4-5 bags.
I drilled 1.5" holes X 18" deep in the rock every 12-18". Put in Dexpan and go do something else. Sometimes it takes 2 hour to 24hrs.
If you get cheap like me drill 1" holes same depth and fill it just takes a little longer.
I watched a man across the street from me rent a air drill, drill 75% of the depth of the rock with 1.5" holes approx 7 foot deep, then took about 4 boxes of dexpan to split it. It did work fast.
Since I didn't have a air drill and compressor I could only drill 18" and it still worked great, just took a little longer. Once it starts crack it doesn't stop. I used about 6 bags on 5 huge rocks.
Good luck
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
16 ft trailer with gate (A52128)
16 ft trailer with...
