PoulanPro 3416 chainsaw
/ PoulanPro 3416 chainsaw #1
Farmwithjunk
Super Member
Mt Washington, Kentucky
Where do I begin.....
Someone who owes me a few bucks wants to satisfy some of the debt with a new Poulan Pro 3416 chain saws. I've got 2 Stihl MS260's that outperform any saw I've ever hd my hands on. However, I'd like to have a second saw with each for those times when I get a bar pinched. He has the original bill of sale, so I know it's not "hot". I was told they sell new fo around $125 (?) Anyhow, what kind of saw is the 3416? Besides CHEAP.
/ PoulanPro 3416 chainsaw #2
IF you use it now & then . It will be ok. I don't know anything about the mod. you listed. But, I owned 1 of their saws once ( 20'' bar) The chain had very small cutting teeth to be a 20'' ( compaired to my husky) Mine didn't hold up very long.. Like you said Cheap !
/ PoulanPro 3416 chainsaw #3
I have seen that saw on sale at HD for $99. I bought one after Katrina when no other saw was available but it was the 18" model. I used it for about 8 hours a day for about 3 weeks before it wore out completely then I returned it for a refund.
Now I own a Husky for my main use and a Poulan "Wild Thing" just for my spare in case I need to cut out my good saw from a bind.
You don't need another saw to get a saw out of a bind.
A spare Bar and chain will do it.
That's what I do now. Rather have a second saw handy just in case. Also, this Poulan saw will be more or less "free". Either I take it as partial payment, or I write off ALL of what's owed to me as a bad debt.
/ PoulanPro 3416 chainsaw #6
I've been using Poulan saws for the past 25 years. Few if any problems encountered, I work the snot out of all of them and treat them like ugly stepchildren. I think Poulan is getting a bad rap on their quality. IMHO best buy for the $.
/ PoulanPro 3416 chainsaw #7
I had one for a few years to mostly delimb the branches off of the cedar trees that I take out. I might use it one day in two months, but it's a full days work. I also used it to cut some oak logs into beams, which was steady running for hours at a time.
The clutch, drive gears just kept wearing out on me. The engine never gave me any problems, and starting was about average, but the problems that I did have just didn't get better with new parts, so I gave it away and went with Stihl.
Eddie
/ PoulanPro 3416 chainsaw #8
* Either I take it as partial payment, or I write off ALL of what's owed to me as a bad debt.
*Take the saw then.
Also you can just grab it instead of changing chains and bars if a saw gets stuck.
/ PoulanPro 3416 chainsaw #9
I would take the saw since you are out anyway. A Poulan saw is not going to be near the saw your 260s are. You are looking at a small pro stihl saw VS. a casual consumer saw.
The Poulan will make a good occasional use saw, just don't expect to make full length cuts with the bar at any speed and don't work them very hard. It will be a good loaner saw. They are designed for the light use homeowner.
/ PoulanPro 3416 chainsaw #10
Couple a years ago 3 of my neghbors helped me grub up our lot line.
2 of them had Stihl saws and the other had a Poulan.
Took the Poulan a lot longer to cut through 6 to 10 inch trees.
*Take the saw then.
There was never any question of taking the saw or NOT.
And if you'd read CAREFULLY, That's EXACTLY what I'd already suggested I'd be using the saw for.
The thread ISN'T a "should I get it or not"question, but a query on what sort of saw this model is (besides just C.H.E.A.P.)
/ PoulanPro 3416 chainsaw #12
in that case take it, put it on craigslist for $90. take your $90 and fill up your pickup with gas once.
/ PoulanPro 3416 chainsaw #13
I've got the el-cheapo Poulan Wild Thing saw. It does very well, for what it is. One annoying thing is, if left with any bar oil in it, it leaks out.
/ PoulanPro 3416 chainsaw #14
I had one of the Poulan Pro's with a 20 inch bar. I used it a few times and then the chain adjuster broke. I also found myself getting burnt on some part of the manifold that was not shielded properly. I didn't like it and gave it away for nothing.
/ PoulanPro 3416 chainsaw #15
I had a poulan pro don't remember which model wasn't impressed with it. Went to stihl.
/ PoulanPro 3416 chainsaw #16
FWJ:
Looks like it is a 34cc homeowner saw with a 16" bar, which makes it pretty much a "throwaway" if anything of real consequence happens to it. I have what might be its big brother -- Poulan 2150 "Wild Thing" and I use it for limbing here in town, does fine, not great, not bad. I usually need something bigger when I am at the weekend place where I have have other choices: Husky 357, Stihl 044, Husky 372XP, or Solo 681. ;-)
BTW, many say the perfect "two saw plan" is your MS260 and either a 044/MS440 or a 046/MS460. I say why have a two saw plan when you can have even more!
RavensRoost
/ PoulanPro 3416 chainsaw #17
I used to work for a logging outfit as a mechanic here in Washington State. When I asked the loggers about a good inexpensive chainsaw, they recommended a Poulan. They also said they would toss the bar and chain, and replace them with an Oregon brand bar and chain. After burning up the factory chain and bar, I did the replacement. It's a much more aggressive and trouble free chainsaw now. The only downside it has compared to the Stihl is power. However, if all you're using it for is firewood or limbing, it's a good chainsaw. After using it for over 18 years, it's now my loaner. It still starts in two pulls and it's has all the power anyone in the neighborhood will need. Besides that, it keeps people from asking for my Stihl or Husqvarna. :D
/ PoulanPro 3416 chainsaw #18
Good Mornin weldingisfun,
Thanks for the sunday mornin chuckle ! ;):)
BTW Bill Im a Stihl man ! ;)
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
