Solar radiant Heat
/ Solar radiant Heat
Today started with rain till 1pm and even in the rain the temp went up.
5:20 am 59.5 top 63.9 bottom 59 degs outside
9:00 am 80.1 top 70.1 bottom 61 outside and still raining
12:00 pm 84.5 top 73.1 bottom 62 outside and raining
2:10 pm 94 top 78 bottom 63 out and clouds
4:30 pm 93 top 84 bottom 64 out clouds with a peeking sun.
24 hrs and it raised the temp from 51 d to 84 d
I like
Phil
/ Solar radiant Heat #63
Great data, keep it up. I knew there was still solar energy when it was cloudy but didn't think it was that good. I wonder if it will be that good when it is zero outside. Reread the whole thread and then read the "Solar Shed" link. Very nice. Thanks for sharing your project.
DRL
thanks,
Today was sunny but I wasn't home to check the specs.
12:pM Top 154d and bottom 110d outside 80
4:30 pm Top 112d and the bottom 104d outside 78
The best news was that the furnace did not start after the dish washer and 2 showers.
The temps are from the solar loops and caused me to be concerned. at 7:30 pm the temps were 74/71 So I was thinking that the bottom reading was giving a close proxcimity of the tank temp. I found this to not be true by touching all the pipes on the tank. The hot out of the tank was hot to the touch where as the bottom loop pipe was cool 71d. This weekend I will install a temp Gauge on the hot out pipe for a more accurate read on the tank.
Is there a way to connect some electronics to this so we can have up to the minute data with out going to the basement?
Phil
/ Solar radiant Heat #65
there are lots of products available for recording / displaying / transmitting temperature. Maybe a transmitter would work for you, this one gives you the probe temperature and ambient (for each sensor installed) Complete Wireless Thermocouple System
This may be a little pricey but it does allow you to install your own thermocouples (surface mount, etc) and it interfaces to your PC through USB.
mwb, thank you but thats a little on the high side. I think maybe a small web cam that I can pan.
On Wednesday the sun was out and the temp was 154 at noon. that night when I got home I noticed the pressure in the sys. was on zero. I added water and it seemed to hold. Thursday night it was down again soI went looking for a leak. It was one of the connectors between the 1" pex and the copper. My guess is the heat helped to set things Now all is good.
I will install the tank temp sensor in the am. I just can't to bring my self to dump all that hot water.:D
The furnace hasn't been on since Wednesday Very Cool!!! or should I say HOT:D
Phil
/ Solar radiant Heat #68
What a great thread, would like something like this some day. My closed loop radiant floor runs off of a 80 gallon heater now, and it maintains a tank temp of around 120 during the heating season (I think it is 190k btu's). Originally it was set up with a 60 gallon tank and couldn't maintain the temp, so the heating guy had to swap it out. Your top and bottom temps are impressive. Do you have an expectation of what those numbers will be in January.
randydupree,
This past week has made me smile:):):) The furnace has only started 2 times. The high temp at the panels so far has been 155.9 and the tank temp seems to max out at 138. To me this is all good.
Maxfli,
I thought that the highest temp would be in the summer. But the angle of the panels help restrict that. I was told that in the winter months the temps will go higher because of the lower angle of the sun. The system has a heat dump valve on the home domestic hot. This is for the winter months. when the tank get to hot the valve will open and dump 2 to 3 gals. of hot water to help the tank from overheating. Time will tell.
(Do you have an expectation of what those numbers will be in January. ) 170 to 195 ish
Frame angle is 60 Degrees In the winter the sun should be hitting the panels straight on.
Now does any one make a flow meter to put on my oil line so I could track the amount of oil use per week?
Thanks
Phil
/ Solar radiant Heat #70
You can probably get a pretty close estimate on fuel consumption using the manufacturers figures for the orifice size you have in the burner X the number of hours it runs. You will need to add an hour meter to the furnace wired off of the burner/pump power so it only counts when the burner is running. I think that would be far easier and less expensive than fitting a flow meter to the fuel line. Also if you know the hours it runs during a week, you can sound your fuel tank and divide the run time into the gallons used. You will need the inches of fuel to gallons conversion chart for your fuel tank.
You can get a DC hourmeter here. Surplus Center Item Detail The only other thing you would need is a small DC power supply to power it, that you can connect to the controller that powers the burner when in operation.
Cool thread, thanks for sharing your results.
Danno1,
Thanks, I ordered one on Friday $32.95
The temps are getting better.
top 163 Bottom 151, and the tank at end of the day 145
Currently I'm trying to catch up on all the other stuff that I've been procrastinating on. I finally bolted the new teeth on the 1260, put the trailer together for the kayak's, mowed the lawn and tested the new teeth. All I can say is WOW !!!. Next week end is me time and I'm going white water rafting:D. Soon we will started the Radiant retro.
Phil
randydupree,
No I haven't done much with the system. Work has been abundant to say the least but no complaints here.I did do the white water rafting so here is a picture of that. The CFS was 8000 and this spot was called "May-tag" river Kennebec
I am installing the pumps and manifold for the 3 zone radiant floor heat. I'll try and post some pics of that tonight.
Phil
Here is the picture of the radiant side. The 3 upper circulator are for the 3 zones. The bottom one is the system circulator. It runs the water from the 2 tanks thru the heat exchanger.
Today the water temp hit 165degs
Phil
Now I have a question that maybe you all can shed some light on why it won't work. My plan was to put the radiant tubing under the floor in the basement between the floor joist. leave an 1-1/2" space and insulate with celotec.
Now I'm thinking that I could remove my pergo floor on top and use 5/8" Sheetrock strips as filler between the rows of pex tube then put the floor back on top. My thoughts are the engineered floor would distribute the weight and the Sheetrock would work.
What do you think?
Also I heard the fed tax credit is back for thermal solar.:D:D:Dup to $2500.00
And today I just completed the Maine state certification class on installation of Solar thermal heat. Now I can get the Maine rebate as well. $2000.00:D
Phil
/ Solar radiant Heat #77
I think your floating floor would eventually crush the sheetrock to dust... I saw an interesting radiant installation at an acquaintenaces new house. It consisted of two 3.5" wide strips of 9/16 ply with gap between them for a pex line to be ran. These 2 parallel strips of ply were joined across the botom by a thin sheet of aluminum that was basically stapled to the bottom of the strips for a total width of about 14.5". The aluminum was to conduct and help distribute the heat from the tube. So basically you have a layer of aluminum sheet across the entire floor, with plywood strips on top and pex running between the strips. There were also milled corners, and the whole thing went down on the sub floor and was assembled kind of like putting together a model railroad set. Once it is down, the pex was hammered into it with a mallet and block. Then your pad and floor or carpet pad and carpet, or real hardwood were placed right over it, of course being carefull not to hole the pex with any fasteners. It was layed out so that the hot water entered the room, flowed around the outside perimeter, then crisscrossed the floor before exiting. 200' per heat loop, with the pex lines spaced at the apparent magic number of 7" apart from each other...
/ Solar radiant Heat #78
sorry, philbuilt, i totally don't get what you are describing in your last post. why not put the pex between the floor joists in the basement, then insulate as usual? you think it would be easier or better to rip out the floor above and lay sheetrock or some other spacing material between the pex lines and then floor over it? maybe just not understanding, but i think running between the joists from below would be much better and easier. i would only build up a floor above if i didn't have access to the underside (slab on grade or nasty crawlspace that's hard to work in, etc.). raising the floor a couple of inches is going to mess up all your door threashholds, baseboard trim, etc and i don't see a performance advantage.
normally, you run the heat tubes between the joists up against the subfloor above (plywood), then insulate below the pex tubes to keep the heat up close to the floor above.
if you want to refloor the living space above, just leave the plywood subfloor in place and finish the actual floor with anything you want. just use fastners short enough they can't puncture you heat tubes.
i would not, under any circumstance, put drywall down as something to be walked on. as posted above, it will crack and turn to dust.
nice job on the copper control valve install. looks good.
to ronmar, i've heard between 6" and 12" is the magic spacing for the tubing. closer spacing near an outside wall or window or run the first loop of hottest water around the outside as your friend did. i've not heard anything magic about 7" spacing. if your joists below are on 16" centers i could see 7" spacing giving you about 4 loops on a 32" width minus the space taken up by the joists themselves. but, if you are pouring a slab, i think you would need to do a heat gain calc to get optimum spacing or just size your pump appropriately to get the heat gain you need. i like the idea of the aluminum foil as an aid to conductance. i think some type of conductor system would help you get faster response from the system and keep the floor temp a little more even throughout the space. just make sure your conductor is well insulated from outside walls so you don't loose what you gain.
amp
/ Solar radiant Heat #79
randydupree,
Phil
Cool picture, there is nothing like WW rush. I did C1 in my old country up to WW5.
RonMar,
My original plan is to put the tube under the floor. here is the reason to do it on top. We built the place on a "as we could afford basis" This part of the house was a mobile home 14x70. all the walls and roof are gone. The frame and floor remain inplace with an additional 3/4" plywood on top then pergo. The floor is also 5/8" lower than the other 3 additions. Mobile floors crown down to the outer walls. Wife wants them level. I figuered that I could kill 2 birds at one time. I did think that the sheetrock would crush as well but, it was worth asking what others thought.
ampsucker,
I will do it as usual under the floor. The spacing that Radiantec suggested is 10" with aluminum plates. A space of 2" and insulate. I will use 1/2" celotec then spray with expandable foam.
My thought on the sheetrock was it would help hold heat longer and distrobute more even though the Pergo.
2008 JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
2008 JOHN DEERE...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T660...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2012 TROXELL...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
