This, that, and the other
/ This, that, and the other
Thank you Eddie.
We didn't put the posts inconcrete. We dug three feet deep holes. We put down six inces of pea gravel in the bottom. Then we tamped in pea gravel to anchor the posts.
We did it this way for a couple of reasons. The first thing is we know that the sapwood will eventually decay even though we sealed it with Penofin red label. If we had put them in concrete they would have at some point developed gaps between the post and the concrete due to the decay.
The pea gravel has locked it in pretty tight. It also has a tendancy to wick away the moisture from the wood. When, not if, there is decay then additional pea gravel can be added to compensate for the decay.
After the posts were set I noticed one of them was out of plumb. We couldn't budge it without using straps and a ratchet. The pea gravel works in this situation.
/ This, that, and the other #482
I think in town, in a yard, and where most people water the yard at least some, the pea gravel is a good way to go. But down in Navarro County, I used the pea gravel for my fence posts when I built the fence around my garden. That was a mistake. That black land (Wilson clay loam, it was called) would get huge cracks when the ground got dry in the summer, the pea gravel disappeared into the bowels of the earth and my fence posts were standing in big holes until I filled in around them. We would literally get cracks in the ground in which you could have lost a golf club. Perhaps if we'd gone deeper, it might have worked.
/ This, that, and the other #483
Harvey,
Thanks, that's along the lines of what I was thinking when looking at your pictures. It's very dificult to get posts to stand up straight without allot of bracing at the top and anchors at the bottom unless they are down in the ground. I've racked my brain on a design for my gazebo's that will do this, but always end up with a short wall at the bottom with metal brackets in cement and angle bracing at the top to do this wtihout setting the posts in the ground. Every method has it's pros and cons.
Eddie
/ This, that, and the other #484
wroughtn_harv said:
The best thing about me asked how you were coming on putting the vines and leaves in the entryway.
How are you doing on that?
UMMM, UMMMM, I'm almost at the point of getting ready to start. I think it will be done before Vin gets here.
/ This, that, and the other #485
Again, another nice project the rustic pergula. Anything Harv does is going to be great. I have a question about these pergulas do the owners plant vines to make a shade roof? Most every home here has a covered porch for shade, we need it. Then there are pergulas everywhere and in the roof people add a sun blocking fabric like this Custom size outdoor knitted shade fabric (shadecloth) and shade netting for sun screen, shade canopy, pergola patio cover, shade sail, lanai cover, arbors or paintball netting or else they plant grape vines. The theory on the grape vines is that in the winter you cut them back to the stalk so the pergula is open and gets sun and in the summer the vines have grown and provide shade. If you plant grapes you choose virgin grapes which has something to do about not attracting wasps. I don't ahve the whole story about the virgin grapes I jsut remember my relatives telling me that. I am kind of puzzled by the American built pergulas I see that are jsut left open without any cover on top.
On our pergula I wanted water protection as well so I bought tarps and they are working really well. We originally thought we would remove the tarps during winter but we ended up leaving them on. The winter sun is lower in the sky and we get plenty of sun under the tarps.
I have literally spent 2 years figuring out how to attach the tarps to withstand the rain. But now I think I found the final solution. I foound these fastners, which you can see int he pictures. I jsut took a small kitchen paring knife, cut into the canvas and used these fastners along with bungie cord and that is what has been working best.
The bungie cords give way a little bit in the extreemly high winds we get here and provide some give. If everything was jsut latched down the pergola builder and the neighbor both said the wind will catch the canvas and rip the whole pergola off the house. I used two canvasses to let the air be broken up. The bottom canvas stays tight but the top canvas attached with my bungie cords lifts up like a sail in high winds. So far so good. Trial and error. I do really like the fact that when I bring in groceries int he rain the canvas is waterproof and I can put things on the patio table while I open the door. You can also see int he first pic that even with the pergola we still get sun in, see the sun on the floor of the balcony. We do ahve plans to make our pergula longer, we built what we could afford and as we sell more olive oil eventually I'll have it completely cover the balcony which is on 2 sides of the house.
You can see in the pics I started out using the grommets in the canvas and steel cable with tenders but that did not work. You can see that the gromets got ripped out. Then as long as I was up on the roof to take pics for y'all I snapped of few pics of our olive farm.
Harv we need mroe sun protection here and we have no air conditioning so that dappled pergula is not ideal over here. I cna't figure out in Texas how it works. The only thing I can think of is everyone must have air conditioning over there and the pergulas are not used on really hot days as people are inside. That's the only thing I can come up with why there isn't more shade provided.
/ This, that, and the other #486
Rox, I've often thought the same for shade versus a pergula...:confused:
BTW, very nice place you folks have over there. I think these are the 1st pic's I've seen of your place. Thanks for posting them.
/ This, that, and the other #487
Kyle, I have posted pics before but now that I think about it not for a long time. We go thorugh periods of intense work, mainly the harvest and the pruning and then the rest of the time just plain old work. So there are times that I am away from TBN or just visit and read and am to tired to post. Right now we are hand weeding 12 acres and also pulling the suckers off the feet of the trees. Actually this morning I played hooky from farm work and jsut read and enjoyed TBN. My hsuband went to clean our condo in Cannes (we take turns cleaning it between vacation rental guests) so he is not here to tell me to get outside and get to work. :) This will be my last post today as I am feeling guilty and need to get out and do my share of the work.
I can't figure it out. I'm now 54 and it seems like 4 years is not all that long but I seem to have less stamina to do manual work then when we first moved here and I had turned 50. Then i think of Harv still going mano mano with the young guys and it encourages me to get off the chair and get moving. Harv you really are an inspiration.
A couple of things for you Rox, one, a week ago our twenty four year old granddaughter visited for a couple of days. While she was here Glenda made something or another with your olive oil. Granddaughter thought it was the best ever. When she got back up to OKC she told her dad about the olive oil. So the ex-son-in-law called Glenda to get the particulars and said he was not only ordering some for his house. He was going to order some as gifts for others. He runs in that kind of circle. Word of mouth, best advertising.
You're right of course about the a/c here in north Texas. Along the coast in California it wasn't necessary. But here, it's not as bad as along our coast, it's still pretty well necessary. You get out of the sun and you only lose ten or so degrees of misery. In drier even though hotter climates the difference is a lot more.
Our arbor makes a ton of difference from two on during most of the summer. In fact this time of year we get almost complete shade in the afternoon and it does make a big difference in the comfort factor out on the deck and back porch.
I'm glad you like work. I believe it is what we're designed to do. Part of the reason I believe that is I've noticed most of the happy people I know like work. And I choose to believe it is the work that makes them happy and not vice versa.
One of the things that I believe makes work easier for me than it seems to be for some folks is my itty bitty bites attitude. I find that I break everything into small increments, itty bitty bites if you will.
You take this afternoon. I had to dig two holes and set two posts. I used a small hydraulic auger to dig the holes. It digs right down with the twelve inch bit to about three feet. The hiccup in the get up always is pulling it back up by yourself when it is considered a two man machine.
So when I dig a hole with this machine there's first the going down. Right now it's tough because the ground is dried down to about four feet so we have these humungous cracks, some of them three plus feet deep. When the auger catches a crack it wants to wrestle. Not with the crack, with you.
When its wetter the clay is a nightmare because after about a foot or so down you have to start adding small amounts of water to keep it from sticking the auger in place. If you let it get stuck then you waste two days energy in about five minutes getting it unstuck.
Going down to depth is one segment, itty bitty bite you understand. Once it's to depth you've got something done, you're on top, do a back pat. You need it because the next thing, itty bitty bite, is a hoss. That's because you have to lift out of the hole the auger with its dirt. No fun at all. Well, unless you do it like I do. You see there's a touch where you spin the auger with the hydraulic control just right as you lift up. If you don't spin the auger at all it's dead weight. If you spin it too fast it wants to keep on going down which is actually a little tougher lifting than picking up the dead weight option. If you spin it just right it comes out nice and easy, back pat one oh one one more time because you need it.
That's because the next thing is you have to get all the loose dirt out of the hole. When it's dry like it was today that's about half a hole's worth. That's done with good old fashioned post hole diggers.
The post hole digger thing is another example of itty bitty bites all on its own. Again, the touch, when you have the touch you bring up the maximum amount of loose dirt possible at a time. Each successful post hole digger maximum load up is an itty bitty bite feel good on its own. Sometimes there's a magnifier in the post hole digger itty bitty bite process. That magnifier is the burn.
You see if you're doing very many of these posthole cleaning excercises you get the good old fashioned muscle burn. That's a trip all on to itself. When you get the burn you know you're doing good and you can do better.
After the hole is dug and cleaned out we get to the itty bitty bite of placement. Step one is putting the post in the hole. It wouldn't be such a big thing if invariably there's a bunch of posts to place in the holes. And just as invariably them posts are heavy.
The next thing is the putting the concrete in the holes. A lot of the time I use sacked concrete. It's what I did today. I only had to do two wheelbarrow loads, two holes, simple math, making the holes big makes the math simple.
Again, itty bitty bites one oh one all over again. You only mix a small batch at a time by adding water to the concrete mix in the wheelbarrow. Each small batch is itty bitty biting all on its own. When you're doing it right you're extremely efficient. When you're not, well, you're not. Inefficiency at this point will eat you for lunch.
When the posthole is full of concrete then it's time to line up the post for height and line. I do it by eye. Some people use a string. That's fine. But have you ever noticed what they do after they set it with the string? They check it with their eye. We get to the same place. I just don't trip as often.
When I was a young man my father told me what he liked about being a fenceman was you got to see progress. When you arrive at the job there's no fence and when you leave there's either a good fence or evidence that there will be one shortly if not sooner.
I bet he operated on the itty bitty bite theory. He just didn't call it that. I believe the pictures Bobby Goodman posted show what I'm talking about.
Rox, I forgot to mention how beautiful your place is. It is gorgeous.
/ This, that, and the other #490
Rox
Your place looks great. All lot of people up here in Eastern Washington use grape vines for the shade. I have a friend who used hops and it works really well. When I finish the pergola I am working on I'll just use shade cloth so I can take it down in winter.
Harvey
I like the little bites idea. I have been working on a pergola since a month before Mother's day (it was 'supposed" to be done in about a month). Then I hit rock and then overtime at work started and I am taking little bites. Of course we may have had a bit of "project growth" in the mix too. :D
/ This, that, and the other #491
Harv, If great minds work alike, how come I think like you? Your little bites (mordida in español), is definitely a good thing. In some of my college work, divide and conquer was the catch phrase used to describe the same concept. If a task seemed too large and complex for a simple enough solution then you needed to divide it into its component parts and those parts into smaller parts until the complexity/difficulty was reduced to a level you could deal with.
One of my best attempts at applying YOUR method of little bites was in designing a way for a single person (or small crew of two or so) to pour and finish a large (2500 sq ft, or any size really) concrete slab. (method available on request) The rebar mat is continuous throughout the entire slab. There are ample control joints to mostly prevent uncontrolled cracking.
Note: Due to limitations of a small crew, maybe one guy, you just can't practically use truck delivery of premixed concrete but instead you use a portable mixer (even I don't like mixing it manually with a hoe or rake.)
To use "THE HARV METHOD" (AKA Little Bites) you don't have to be able to lift 1000 lbs but you do have to be willing to lift a single pound, a thousand times.
Pat
/ This, that, and the other #492
Pat
That is good. I like that and will use it again myself. Thanks.
/ This, that, and the other #493
After you divide the work up into small bites, I know in some cases, those small bites have to be done in a particular order, but on some jobs (or multiple jobs) you can decide for yourself which to do first. So how do you decide.
Personally, I always liked to do the worst jobs first, so wherever I was in the process, I could always figure the worst is behind me.:D But I remember when I just a kid that my Dad said he liked to start with the easiest job, so he could always figure he was doing the easiest job available.:D
/ This, that, and the other #494
Patrick,
To use "THE HARV METHOD" (AKA Little Bites) you don't have to be able to lift 1000 lbs but you do have to be willing to lift a single pound, a thousand times.Me too I like the way you worded this and this is literally how we farm.
There is lots of equipment ww will buy one day but for the moment is is one pound a thousand times.
harv,
I am so honored that your daughter recognized that the food tasted better by using our oil and that perhaps we ahve some new customers. We really do appreciate every single bottle of olive oil sold.
Bird,
I'm with you I always do the hardest job first I cna't stand to have it hanging over my head.
All- After Harv's encouragement I got my mojo going and I have been hard at work ripping the sucker branches off the feet of the trees. I guess by wrting it down that I thought I was perhaps slowing down it motivated me to get going and get moving. When you are self employed and are not serving any customers on any jobs then your schedule is mostly your own. It is kind of easy to fall into procrastination. Thankfully between my husband and myself we prod each other if one of us starts slacking. I am determined not to slow down and blame it on being 4 years older. Since I first wrote I have been working everyday at a good clip and it sure feels good. I relaly value this TBN community, well except for one member and I won't name names but Bird prolly knows.
/ This, that, and the other #495
After sub dividing a large or complex task into sub tasks and maybe some of those sub tasks into sub sub tasks (lather-rinse-repeat as needed) you may find some tasks are independent and can be done at any time while others have a rigid sequence . For example: you don't install the shingles before you build the roof but you can build the fence around the house any time.
Decomposition or successive decomposition is the professional term for breaking a task into its component parts. With experience you learn how far to go in the decomposition of tasks into ever smaller tasks. Once a task is decomposed into small enough pieces that you and or your compadres can wrap their minds around it then don't simplify any further. For example: lunch break shouldn't have to be broken down into simpler pieces for anyone.
A very important part of this systematic approach is to know what the required inputs are to a process and what the output(s) is(are) you get out. This relates directly to Bird's question of how do you decide. If a process requires say three inputs... You need electricity to the job site area of this sub task, you need water to this location too, and you need one particular non load bearing stud wall framed up to accept the installation of some thingy. So before you uncrate the thingy and try to install it you first have to have electricity and water and the stud wall.
Experienced contractors sort of employ this process casually and informally to build a simple house or whatever. Architects, engineers, and tradesmen erecting a sky scraper tend to get a bit more formal with their plans and have detailed written descriptions of the broken down tasks.
Not everyone can intuit the flow of work in a complex job, especially if it requires coordinating the efforts of various groups of workers or even applying your own labor in the proper sequence of events. I find that I NEED to think about a larger or more complex job in these terms when the consequences of "messing up" are not trivial.
I am currently in the process of moving a 35x70 foot metal bld with 18 foot side walls and 14x14 foot roll up doors at opposite ends. I am moving it about 1/4 of a mile across one of my fields to a more convenient location. One of the early sub tasks was to empty the bld. But... what do you do with the contents in the mean time? So a precursor task to emptying the building was to build some 4x4x8 ft boxes to store stuff. I also emptied out 2 each 20 ft steel shipping containers, dragged them out of the bld and refilled them with stuff.
I also had a pad constructed to accept the bld. Now I need to have piers dug by my driller who can do 16 inch piers up to 24 ft deep. I need to fabricate weld plates to set in the concrete of the cast piers. I need to build "boots" to raise the pipe columns of the bld to make up for the fact that I will not be pouring a floor or a foundation or stem wall. The current situation has a ledge in the poured floor to accomodate a few inches of overlap of the metal siding. If I just sit the cut off columns on the weld plates I will crush a few inches of the bottom of the siding all the way around the building. So I will make "boots" out of the next larger size pipe to raise the building 6-8 inches. I will then be able to see "daylight" all around the building. I can use pressure treated wood set into the soil an inch or two and be screwed to the metal siding. Thus no earth metal contact, just wood to dirt and metal to wood.
This is my first building move of this sort so I had to break it down into bites I could easily understand and chew one at a time from start to finish to be sure everything was going to flow smoothly. Now it is raining and I can't get the driller on site. If it rains enough with insufficient time to dry between rains I may be "rained out" and the next window of opportunity will be after the ground freezes enough to take the load (if the winter is cold enough.)
Anyone have a discount ticket for a heavy lift helicopter?
Oh by the way there are lots of different pieces of competing software that simplifies decomposing a job into tasks and subtasks and tracks the input requirements and outputs. If estimated times to do the various tasks are input then the software will help you estimate several things rather well, including: the "critical path", lay times, total time to complete and such.
These software applications typically support PERT charts, a powerful management tool. For info, Google on PERT chart.
Pat
/ This, that, and the other #496
Pat, I see at the very end of your post, you got to the "PERT" chart, but way back up in the middle, I was expecting to see mention of a "FLOW" chart.
/ This, that, and the other #497
Bird, A PERT chart IS a flow chart. There are several kinds of flow charts and the PERT is one of them.
They are all tools and as in other disciplines you need to know what tools to use to best accomplish a task. The best tool in the world can be useless when brought to bear on the wrong sort of problem.
A simple flow chart will not provide the information you can get with a PERT chart. Some jobs are not complicated enough to warrant the overhead of a PERT chart but many are.
Pat
/ This, that, and the other #498
Yep, but before I was halfway through reading that post, I was expecting to see "flow chart" and just wasn't thinking of the PERT chart until I got near the end.
I had a little experience with them when I was the department's project manager when we built an entirely new combined police & fire communications center in a new City Hall, and then later was the department's project manager when we built a complete new police auto pound on undeveloped land; storage facility, auction facility, office building, parking lot, etc.
/ This, that, and the other #500
Bird, Why am I not surprised that you were a chart using project manager...
Egon, Thanks anyway for the lead on the chopper but you sent that site's URL to me before. I still have reservations regarding their current air worthiness certs.
CPM (Critical Path Management) is a common tool.
At times I was so immersed in such that I would dream in charts! When I taught evening courses in software engineering to university seniors I also took on their senior projects classes that were three each 5 quarter hour courses in a row. A couple times the team projects (5 person teams) were to develop a computer based tool for project management along the lines of CPM. (Not to be confused with CP/M (Control Program for Microcomputers, an operating system originally created for Intel 8080/85 based microcomputers.)
Pat
(5) Round Straw Bales (A66408)
(5) Round Straw...
2007 International School Bus (A64194)
2007 International...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
Linx EQ07018RS 18ft Trailer (A65640)
Linx EQ07018RS...
(12) 4.5"x9' Steel Posts (A66408)
(12) 4.5"x9' Steel...
