Price Check zero turn mowers and price differences
/ zero turn mowers and price differences #1
Nat
Platinum Member
Central NC
I'm looking at new mowers and have found a huge difference in price for several mowers that look comparable to me.
1. Cub Cadet Z-Force--3995.00--22 hp B&S
2. Yazoo/Kees midmax--4995.00--18 HP B&S
3. Great Dane Chariot--6000.00--17 hp Kawasaki
4. John Deere 717 Z-trak--6400.00--19hp Kawasaki
All are 48" cut
All are 2 lever steer
these are the prices they are selling for at several different places, so it's not a location difference.
I know the Great Dane, and the John Deere are the same machine, made in the same place, a couple small differences, but really identical.
am I missing a big quality difference, that anyone knows of, or are they equal except for price. Anyone have any of these mowers, or have any opinions on them? I would sure appreciate any help.
Thanks, Nat
/ zero turn mowers and price differences #2
/ zero turn mowers and price differences #3
Nat, I have been looking at ZTR's for a while now, and I think the pricing differences can be explained by a few features (or lack of features.) One area where the machines differ is in the drive. The cheaper units use a non-serviceable intergrated unit that has a life span of 800-1000 hours, according to the manufacturers. Heavier duty machines have a pump and wheel motor design, that is serviceable by changing fluid and filter.
Another area seems to be the construction of the mower deck. Generally, the more expensive units have heavier construction in the deck area.
Hope this helps,
Will
/ zero turn mowers and price differences #4
Take a look at the Lesco Z Two. Same exact machine as the Cub Tank (MTD makes both). Price is $5995 for a Kawasaki 25HP with 60" fabricated deck. This unit is VERY heavy duty. Don't be afraid of the MTD connection. They make all cubs now (and a bunch of other brands) because they own Cub Cadet. This machine is made for, marketed to, Lawn Care Professionals.
/ zero turn mowers and price differences #5
Nat,
What kind of material are you mowing, grass, weeds,etc. The mowers your looking at seemed to me under powered. Most people buy ZTR's to mow fast and have a longer life span of average lawnmower. I have a 27hp Kolher on the Ferris 3000GT and mow mainly bahia grass which is very hard on maintaining blade sharpness. The extra hp lets you plow thru the taller and denser grasses. All my neighbors brought the under 22hp ZTR's and mow at much slower speeds than I can mow at. I avg around 8 to 9 mhp and usually mow my 5 acres in 2.5 hrs, compared to the neighbors 20 hp ztr 3.5 hrs in mowing the same acreage. The extra 5 to 7 hp makes a differance in time and quaility of cut. $6500.00 plus is a lot of money for a ZTR but you usally get what you pay for in productivity and live span of the product.
/forums/images/graemlins/cool.gif
db
/ zero turn mowers and price differences #6
I don't know about the others, I just got rid of an Ariens 1648 zero turn, nothing but problems, so much so that when i emailed the factory about problems with the ground speed not being even after 3 warr. calls and having had one side "transmission" replaced (whatever that drive clutch system is called) that the "official" answer from the factory on getting the ground speed correct was "let air out of the tires on one side"-----yep thats the kind of factory service i wanted.
/ zero turn mowers and price differences #7
I would like to know more about the John Deere 620 Z tracks.
Unlike some of the other ZTR's the JD 620 has 3 sets of wheels instead of the std 2 sets. I would think that the 3rd set of wheels might offer more stability on the hills or uneven terrain.
Anybody here have one of these JD 620's?
Thanks
Yooper Dave
/ zero turn mowers and price differences #8
</font><font color="blue" class="small">( Most people buy ZTR's to mow fast and have a longer life span of average lawnmower. I have a 27hp Kolher on the Ferris 3000GT and mow mainly bahia grass which is very hard on maintaining blade sharpness. The extra hp lets you plow thru the taller and denser grasses. All my neighbors brought the under 22hp ZTR's and mow at much slower speeds than I can mow at. I avg around 8 to 9 mhp and usually mow my 5 acres in 2.5 hrs, compared to the neighbors 20 hp ztr 3.5 hrs in mowing the same acreage. The extra 5 to 7 hp makes a differance in time and quaility of cut. $6500.00 plus is a lot of money for a ZTR but you usally get what you pay for in productivity and live span of the product. )</font>
Ground speed is a big factor for large, open areas. It is not much of a factor for the type of lawn service that does lots of small yards or places with lots of trees. Around here, about 90% of the full time lawn services use Walker mowers. They are certainly not fast in terms of raw ground speed. They are extremely manueverable and with the deck out front they can get under most bushes. String trimming is kept to a bare minimum. Consequently, the Walker consistently outperforms nearly everything out there for smaller yards. They are expensive. I believe the cheapest model with a 38" deck and 15hp air cooled engine is around $6000 with the grass hopper. You can spend over 10 grand for the bigger models. The other feature they have that saves tons of time is a large grass capacity in the hopper and the ability to dump it in a trailer without getting off the mower. You steer with the fingers on one hand. It is very simple to operate. I tried one out at the dealer last year.
When I'm done with my landscaping chores and don't need a tractor anymore, I'll probably sell the Kubota BX and get a Walker. The Kubota ZTR is also tempting. I guess it depends on what my kids will be doing with the mower at that point.
/ zero turn mowers and price differences #9
I have driven the front mounted decked 687 and older models and they have the Kohler V-Twin, and the deck piviots so when you go over a large bump or hill in the ground you feet will rise up too since your foot rests are built into the mower deck. I don't get what you mean by 3 sets of wheels. There are the front drive wheels and the 1 or 2 rear casters by the motor. 2 wheels are optional or at least they were. I personally like them more than the normal Z-tracks since you can trim under trees. Oh as for stability, you can get the back of the machine to come up very easily if you go forward fast then hit reverse quick! Since it piviots it is bouncy!
/ zero turn mowers and price differences #11
Nat,
I do not have any expericence with the specific brands you asked about, but if you drive all those models I'm guessing the price difference will be better understood. If your considering spending 6k for a ZTR you might want to check out SCAG. They only make commercial ZTR's. 6k will get you one with 48" cut. ExMark also makes good ZTR's. I bought a SCAG Wildcat 27hp Kohler vtwin, 61" deck and really like it. My yard is not real smooth so I do not mow at full speed, but I still get done quicker than I used to. Mowing around trees and whatnot is a breeze. I have turf tires on mine and it does fine on my little slopes. I've seen some ZTR's on landscaping trailers that have something like R4's on em. I don't need them, but its good to know they are an option.
Moon of Ohio
/ zero turn mowers and price differences #12
Yooperdave: I have had a JD 620ztrac for about five years now, bought it new with the collection system. I love the machine, have had no problems and does a great job mowing. If I were buying for lawn mowing ( I mow 2-3 acres of lawn) with lots of trees, landscaping,etc a ztr is the only way to go for me. There are some operator learning curve issues for steep side hill mowing, best approached straight up and down, and if you have the collection system where you dump from the seat (great feature plus good for leaf collection-don't blow leaves anymore- and composting) you will learn to watch the outside upper corner so not to hang up and bend the dump lever, which I do a couple of times each year just so I can keep in practice straightening it back out. Would I get the 620 again? Yep, in a NY minute! Other ztr's are probably just as good, but I have a good Deere dealer close, and I'm a JD guy.
/ zero turn mowers and price differences #13
Well, there are many suggestions regarding the "best" ZTR but since I have a Ferris product then I consider them the "best" /forums/images/graemlins/grin.gif All kidding aside, when I was researching ZTR's the one point that kept surfacing was price. You get what you pay for. So I purchased what I considered the best price for my needs. My Ferris 3000is has rear wheel suspension, built like a tank, 25hp kawasaki engine and I paid $7500 brand new. Here is a PIC of my Ferris 3000is
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
(APPROX. 85) 1X6X11 ROUGH SAWN PINE (A64276)
(APPROX. 85)...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
