Zero Turn Mods
/ Zero Turn Mods #51
My Jd 997 came with lights from factory. I only use them when running out the lane at night to the mail box hahah to many bugs mowing at night where I am
/ Zero Turn Mods #52
Iteresting. Are you thinking wishbone or strut or? I've seen a couple that have shocks in the front but sure that it's a actual independant.
I am thinking of an A-arm type set-up utilizing a shock on each side.
/ Zero Turn Mods #53
Ferris mowers have models with front end only with suspension and also with full suspension. May want to at least look at their design.
The Ferris uses independent shocks like I was thinking - Now the rear wheels being suspended too... humm, that may prove to be a bit more difficult - plus I suspect to maintain cut height uniformity would add some complexity too. Just letting the front some independence would compromise cut height uniformity as well, however, I ok taking a stab and seeing it would permit an amount that is acceptable.
2015 MACK GRANITE GU713 T/A DUMP TRUCK (A59823)
2015 MACK GRANITE...
2019 KUBOTA SIDEKICK RTV-XG850 (A62130)
2019 KUBOTA...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
