Zero Turn Mods
/ Zero Turn Mods #41
My question is... Why do you want lights on a lawnmower? You don't mow lawns in the dark because the grass is wet. Mowing wet grass is a big NO. My ONLY modification to my M60 Tank is a set of am/fm noise cancelling muffs.
/ Zero Turn Mods #42
Depends on the mower... I have often mowed after the dew has set or before it burns off.
Is it ideal? Not really, but after I am done, you would be hard pressed to tell that I had mowed it when it was damp.
Aaron Z
/ Zero Turn Mods #43
Aaron Z
Same here. I prefer not to mow when it's wet, but my grasshopper produces the same results wet or dry. A heavy dew or light rain keeps the under side of the deck really clean. Heavy rain creates more grass buildup under there. The worst thing about mowing when wet is that the wet grass sticks to everything (the mower and me), rather than blowing off when dry.
/ Zero Turn Mods #44
Aaron Z
/ Zero Turn Mods #45
I like to mow in the late afternoon with temps in the upper 60's and humidity around 30%. Guess how often I have those favorable conditions. Working fulltime, weather and schedule conflicts force me to mow some times I'd rather not. A few years back I was working almost 2 hours from home. That Spring there were very few times I could mow in the daylight. If I retire maybe I can schedule things better.
/ Zero Turn Mods
The nice thing about these commercial grade zero turns is that they are made to be able to mow wet grass. The tip speeds are a lot higher and they are able to lift the wet grass blades and discharge them without any problem. The commercial guys just can't wait for the morning dew to dry off! I would agree that it's not the ideal situation, but when it's between taking up my whole Saturday and mowing during the week in the evenings after work, I'll take the evenings!
/ Zero Turn Mods #48
Going to attempt to Revive this thread - Has anyone attempted to make their front end's slightly independent. I am thinking this would greatly aid traction at the rear wheels. I am thinking of doing that to my Hustler over the winter months.
/ Zero Turn Mods #49
Iteresting. Are you thinking wishbone or strut or? I've seen a couple that have shocks in the front but sure that it's a actual independant.
/ Zero Turn Mods #50
Ferris mowers have models with front end only with suspension and also with full suspension. May want to at least look at their design.
/ Zero Turn Mods #51
My Jd 997 came with lights from factory. I only use them when running out the lane at night to the mail box hahah to many bugs mowing at night where I am
/ Zero Turn Mods #52
I am thinking of an A-arm type set-up utilizing a shock on each side.
/ Zero Turn Mods #53
The Ferris uses independent shocks like I was thinking - Now the rear wheels being suspended too... humm, that may prove to be a bit more difficult - plus I suspect to maintain cut height uniformity would add some complexity too. Just letting the front some independence would compromise cut height uniformity as well, however, I ok taking a stab and seeing it would permit an amount that is acceptable.
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A62131)
UNUSED RAYTREE...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Kubota M4700 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
