Your towing rigs and trailers
   / Your towing rigs and trailers #3,181
Perfect thank you. That last picture was exactly what I was looking for.
I figured with the channel iron sitting on the lip of the trailer I didn't have to worry and if I ever did feel like I need to I can put some weld on the channel. it has been a year and around 1000 miles since I did it.
   / Your towing rigs and trailers #3,182
I love this Diamond C trailer.
   / Your towing rigs and trailers #3,183
Nice looking trailer. Looks well built. I like the built in tool box in the tongue (based on what I saw on the manufacturer's web site). I guess for twice what a typical equipment trailer costs it should be a Cadillac!
Rob
   / Your towing rigs and trailers #3,185
I'da told them drop some of the fancy options and add few more feet of trailer. It appears that something like a backhoe or rotary cutter are going to hang off that. It is a beautiful trailer for the load it has, but if you ever need to take a few implements with the tractor, it won't fit.
   / Your towing rigs and trailers #3,186
It's 20' and yes, I kinda wish I'd went with 22' only to be able to rest the backhoe boom on the deck for transport.
This one works for me. Doesn't get must use in winter. This photo was a couple of weeks ago when I was transporting to the dealer for some repairs/service. When the backhoe is attached, I have a 60" grapple inside the 72" bucket. It's got 7k axles and crossmembers are 12" o.c.
15ply tires. It was on the lot, I made an offer, the dealer accepted. I like the fancy options. Especially the blackwood and that box for chains/binders/ and straps.
   / Your towing rigs and trailers #3,187
As long as it fits what you need to haul, that's all that matters. Before buying, I had the opportunity to haul my stuff on my brother in law's trailer a few times. A couple of the jobs I was doing, I had to make a second trip to get all I needed. I loaded up a couple implements on my small trailer before loading the tractor on the BIL's trailer. Took the tractor onsite with his and dropped it, then returned for my trailer of implements. Took the better part of a day. That situation made my mind up to go big on the deck. Apparently 22' or larger bumper-pulls are not something most manufacturers build for stock on dealer lots, they are special order.
   / Your towing rigs and trailers #3,188
I have found all are 2' short too often. :)
   / Your towing rigs and trailers #3,189
Very NICE trailer! The angle in the pic makes it difficult to get a good idea of length. 20' looks like it works pretty well. I have to confess envy of that Blackwood floor. Nice stuff!
20' trailers are more common than most other sizes in stock on a lot of lots that I see. Very seldom see a 22' in stock.
TBS
   / Your towing rigs and trailers #3,190
How does that blackwood rubber do if you haul material like gravel or dirt on the trailer? I use my equipment trailer occasionally to haul this stuff and it works great to just drive my MCUT (Deere 2520) up on it to remove the material with the loader. The treated 2x8s hold up great for this but I wonder if the rubber stuff would get destroyed?
I can definitely see the benefits of blackwood if you exclusively move equipment on the trailer.
Rob
   / Your towing rigs and trailers #3,191
Blackwood Lumber – Blackwood Lumber
This is interesting decking material. I want to keep my eye on this brand and competitors in the future. Sounds great for horse trailers for sure. One rainy day coming back from a parade my daughter put the brakes on hard when the tilt bed started to break over and the tractor slid all the way down until it reached the driveway. Thankfully the axles were level so it went off the tail and not the side.
   / Your towing rigs and trailers #3,192
Nice! We have a pair of the Diamond C 48HDT that we use for deliveries. We went with the 22' only because we often have a backhoe and a rotary mower to deliver along with the tractor/loader and that takes up some deck space. Both of ours have the heavy duty fenders like yours, and we also went with the 17.5" wheels with HD tires and we mounted winches on both trailers. No doubt they are expensive, but that is a lot of trailer. With Diamond C, you can just keep checking boxes, pick your axles, your length, your cross member spacing, paint color and so forth. The painful part, if you get carried away, is it takes a while to get a custom trailer, and all of that hot rod customization does cost something.
We mounted the winches inside the toolbox. Out of sight, probably less likely to get stolen. Then we have a removable panel in the deck where the cable comes through for when we are using the winch.
You have a nice looking tractor - trailer package.
   / Your towing rigs and trailers #3,193
Dave, I bet some people, like me, would enjoy seeing pictures of that winch set up if you would care to post them.
TBS
   / Your towing rigs and trailers #3,194
TBS
I'd like to take the time to clean the trailer up and not have it parked in a puddle, but then I'll probably not get around to posting the pictures if I did so. These are working trailers, used pretty much every day on deliveries. The fair lead slips into a receiver on the tilt part of the deck. The deck can be locked in the up (fully tilted) position if need be, or any position. When we remove the winch panel from the deck, what you see below is the ground. We have a d-ring to keep the cable in place for storage, and also another d-ring in case we need to double back. Hope that makes sense, and sorry for the poor pictures. I included a picture of the heavy duty wheels with 17.5" tires and the oil bath axles. Same picture shows the 3/16" thick fenders.
fairlead.JPGfront.jpgwheels.JPGwinch panel closed.JPGwinch panel open.JPGwinch.JPG
   / Your towing rigs and trailers #3,196
Rob
I don't use it for material. I'm on my third dump trailer, as I'm an abuser when it comes to volume and material bulk loads. Plus the ease of unloading warrants the dump trailer.
The blackwood is a definite plus, especially when there is snow/ice involved.
   / Your towing rigs and trailers #3,197
Quite the trailer!
Could shorten your winch power cables a few feet though..
I'm afraid to even look up a price.
   / Your towing rigs and trailers #3,198
Quite the trailer!
Good point on the power cables. Shorter cables gives less voltage drop. Probably what was handy when they installed it in our shop. Prices aren't bad on the Diamond C compared to other heavy duty commercial grade trailers. In fact cheaper than many other brands, but a lot more than a mass produced car hauler or a simple equipment hauler. We sell them and the contractor hauling a 10,000 mini-ex or a big skid steer won't bat an eye at the price as he sees the quality and is towing heavy every day. But a trailer like this is just not needed for most non-commercial applications.
We have a heavier trailer for deliveries also. A 32' 25,900 lb tandem dually goose. Has a power dove, power jacks, and 12k axles with hydraulic disk brakes. It stops so well. But every box you check costs something. That tandem dually power dove disk brake trailer lists for over $20k.
Diamond C is innovative. For example, their 14,900 lb low profile dump can come with the standard scissor lift or an optional front mounted telescoping ram...sort of like a real dump truck. Many options.
   / Your towing rigs and trailers #3,199
I hate it when people say this, but if you can afford the trailer, you can afford a crimper. hehehe.
https://www.amazon.com/dp/B07D7Q54N2/ref=cm_sw_em_r_mt_dp_U_UOEsCb0W2QZ5Z
Then you have enough cable for next time, too.
High current in a coil, it may generate some EMI.
As if it matters, I know.
It's just kind of funny to me, because an engineer friend (I'm an engineer too, but never thought about it) commented about the build/quality of my dad's trailer. It's a 20 year old equipment trailer that's hauled a *lot* of shi......stuff. It's no car hauler, but it's apparently not a Diamond C either. For some reason I like trailers.
The trailer wasn't the point of the picture, but this was the load (pallets of wood is all).
   / Your towing rigs and trailers #3,200
So then, why did you say it? Haha.
No doubt we need to shorten the cables and we have the tools to do it.
2022 John Deere 5055E (A60462)
2022 John Deere...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
207273 (A52708)
207273 (A52708)
RUT E-TS-36-36" HYD TREE SLAYER MOWER (A60429)
RUT E-TS-36-36"...
iDrive TDS-2010H...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
