Your last generator Maintenance Run
   / Your last generator Maintenance Run
The times can be changed by a service tech. He can plug in a laptop and tweak them
Granted that some/many customers shouldn't be let near a programming panel, but I can see that being a pain. In remote areas, getting somebody to show up for just a service call can be a problem - you know the business economics well... Lots of guys will install.......
I'm a ways off from buying an auto-start system, but when I do go looking at them, I'll be checking for ambient temperature sensors.... it would be less than child's play to design that for extended test runs a low :cold: temp.
Rgds, D.
   / Your last generator Maintenance Run #322
Rgds, D.
for $266.00 you can get slip on heater for oil filter and battery heater. They plug into the 2 yellow power lines from the house panel. 10 mininstall. Self regulating 240 volt heaters. That, and the onboard battery maintainer.... Once a week or once a month cycling is fine
or... In 2 minutes you can reset the auto exercise cycle betwen weekly, biweekly or monthly timer using the onboard electronic touch pad control.
Those heaters are a good option, up north. What wattages are they typically ? Nice being thermostatically controlled.
Rgds, D.
   / Your last generator Maintenance Run #324
Rgds, D.[/QUOTE
Battery 50 watts, 240 v
oil filter 44 watts, 240 volt
   / Your last generator Maintenance Run #326
Just had a power outage this afternoon. Power went off at 3.30pm and I waited for an hour with nothing happening. Started the back up generator and put it on line around 4.30pm. Still running and if I don't get power back I will be shutting it down at around 9.30pm.
Temperature here has moderated quite a bit - it is now +8C and windy, raining - just over a week ago it was around -25C and snow 18" deep.
I am very glad we have the generator - life could be pretty miserable without it.
A little unplanned exercise for your diesel Jim..... I'm thinking you have a decent sized fuel tank on that, it should keep you comfortable for quite a while.
Rgds, D.
   / Your last generator Maintenance Run #328
Hi Dave,
Yes, the fuel tank is a household 250 gallon heating oil tank (in like new condition) sitting on blocks off the ground, inside a purposely built shed - next to the generator shed. I also have clear plastic hose arrangement on the outside of the tank, that shows me how much diesel I actually have in the tank. With the red colouring of the diesel fuel against a white back round makes for easy reading.
Cheers
   / Your last generator Maintenance Run #329
Ooops, I forgot to add this pic.
Nice setup Jim !
Looonnngg run time between fills :thumbsup: .
Rgds, D.
   / Your last generator Maintenance Run #331
I did a maintenance run on one of mine yesterday, and decided to start this thread as a reminder-to-self to do this a little more often.
I had some issues with my old gen last year, detailed in another thread. Part of my corrective action plan (to what was reasonably careful storage in the past) is to run my generators at least every 2-3 months.
I disagree with your basic premise. 'Maintenance' running implies keeping fuel in the gas tank, which I would consider the exact opposite of maintenance.
I put my generator away with clean oil in the sump, and a completely dry fuel system - do the same things with my dirtbikes, mowers, snowblower, garden tractors, etc. I just ran my generator for the first time in 3 years last week. I pulled it out, filled it with gas, one yank on the pull start and it was purring like a kitten.
As I've commented before Jay (probably even in this thread), regional fuel variations can be a big factor. Some folks experience (just to pick one component of fuel) huge problems with ethanol, some people report zero issues.
I went down this (store stabilized and full) road after experiencing carb problems running my generator dry. I bought the generator new, so the problem was not due to anything a previous owner got up to.
One of the things I've enjoyed in this thread is seeing what works well for people in different locations.
Wherever someone lives the key question is, Does your equipment start reliably ? This thread, and others, contain differing practices that achieve the same goal.
I have no particular interest (neither at the start of the thread, nor now) in converting someone to approach I use. If someone is having problems, a thread like this can give them some options to try.
Between regional climate and fuel differences, I can see that there is no one-size-fits-all answer.
Rgds, D.
   / Your last generator Maintenance Run #333
I ran my L70 Yanmar with a 3.5kw resistance load for a little over an hour. This is a new engine mated to an old 5kw gen head. When I start it I like to get it thoroughly warmed up.
I recently rebuilt a Honda EU2000i which was given to be because it burned oil so I ran that thru 2 plus tanks of fuel (1.1 gallons) for 20 plus/minus hours running a 1hp blower motor.
I ran it in Eco mode and off Eco mode to ensure I fixed the oil burning problem. That EU2000i is a really nice quiet, thrifty generator.
I would not mind having their new EU7000i!!
90cummins
   / Your last generator Maintenance Run #334
I ran my 60KW last week for a kids carnival. Powered game booths, food stands, rides, lighting, music DJ, etc.
90cummins
Honda has always had pretty good offerings. Quiet and easy on fuel wins 'em lots of fans. There's a bit more competition now, but they had that end of the market pretty much to themselves for a good stretch.
Rgds, D.
A "bit" more work to set up than my loads, but sounds like a lot more fun ! :jester: :clown: :fortuneteller: :magician:
Rgds, D.
   / Your last generator Maintenance Run #337
Some posters on TBN could use that 60kw unit for their house.
   / Your last generator Maintenance Run #339
I have been working away from home a lot lately and felt behind on my generator maintenance.
I just happen to be home gor 4 days, and yesterday they were calling for a lot of freezing rain. I went un the garage and tried to start the generators. The honda EU1000 started fisrt pull ( this one belong to my brother). The yamaha powered 2800 off brand generator started first pull, but I could not get my 3000/4000 champion to start, the gas in it is from hurrican arthur last summer..... I am flting back to work tomorrow, but I will try to figure this out when I'll be back... Hopefully it is just a ild gas issue.
   / Your last generator Maintenance Run #340
I was given a Champion that I heard run sweet last year... folks were moving and asked if I wanted it.
No go a couple of weeks ago... be interested what you learn.
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
2000 Sterling L9513 Winch Truck (A61306)
2000 Sterling...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
