Your last generator Maintenance Run
   / Your last generator Maintenance Run
Date: Dec 18/14
Generator: 7kw Briggs
Activity: Ran 1 work flood light, 1000 watt heater, and shop vac'd the Civic.
Final Fueling notes: filled w. NonE gas. Stabil 360 Protection already in fuel can. Added Lucas fuel treatment to generator tank.
Maintenance notes (Done, or Required):
Electric start. Full choke used; started 3'rd crank. Temperature -3 deg C. Try a bit less choke on next Elec. start. Battery @ 12.99v rest voltage, after starting and before charger attached. Oil level good.
Rgds, D.
   / Your last generator Maintenance Run #362
I have been keeping used Onan RV gens in mind, "just in case" the right project comes along :D .
A well regarded line like that, pulled out of RV duty (often fairly low hours), can be a great deal. May need some TLC from sitting too much, but that's no different than most used gens.
Bonus marks for being already designed/built for Remote Start.
heres a few pics of the old girl. if i remember correctly i purchased it used in 1993. still works great. electric start with manual transfer switch. i added battery maintainer and magnetic oil pan heater(hooked to a plug in tstat to shut off in warmer weather.).
Just started it again today. fired right up
Any pics GRS ? I don't think we have any Onans up here yet.
Rgds, D.
Just started it again today. fired right up. When i installed it. i simply extended the inclosed 3 wire toggle switch indoors to my panel.
i forgot how old looking this unit was. 21 years does start to age the system. The indoor panel was also a used GenTran system that i removed from a previous job years and years ago. I figured it still worked, so what the heck.
I removed it to install an auto start system.
When i finally replace my system, im planning on installing a 27KW Liquid Cooled quiet source system with full auto transfer switch. Ive installed the 48KW version and really liked it. I dont need that much power in my mostly gas house though.
Heres some pics of the Generac transfer switch installed. nice units IMG_20140714_142937578.jpgIMG_20140726_115057763.jpg.
I dont take many pics of completed jobs...not sure why. most of my pics are ones i take while bidding jobs. I really should take some progress pics.
This one job was pretty difficult to add transfer switch due to the fact they set the meter so close to corner of wall. Utiulity company wanted $2700 to move meter....like that was going to happen. So i designed a work arround. kinda busy looking, but 100% legal. Owners didnt mind looks as it is buried in back behind movable firewood rack. IMG_0214.jpgIMG_20141217_135254979.jpg
Thanks for the pics grs, always good to see how a pro does things.
I'm a Function over Form guy, so I rarely have a problem with something that looks older. Been around long enough to appreciate that some older products and systems were designed for longer life-cycles than what can be typical today - so I appreciate that aspect too.
While there is the occasional bit of new tech that delivers functionality I like (IP based remote telemetry), in many respects I prefer things like olde school analog meters a lot of the time.
You sound busy enough that you don't need New Installation pictures to drum up business..... but pls keep us in mind when you do your 27 kw - I'm sure I'm not the only one here who'd like to see that installation.
Rgds, D.
   / Your last generator Maintenance Run #364
funny thing is, the old Onan genset was only installed for a "few months" until real power was installed on my property. I really never intended to leave it there.
I built my house on it. we didnt get a real underground service install until 2 months after the house was roughed in.
I keep meaning to replace this unit with one set out by my main 400 amp panel. i just keep putting it off cause this old one just keeps going and going and going.
   / Your last generator Maintenance Run #365
   / Your last generator Maintenance Run #366
I've only know good service from old Onan gensets... lots of them still out there.
   / Your last generator Maintenance Run #367
End of Nov./14, standard oil & filter change on 20kW Briggs propane genset. Ran and tested for leaks, oil level, etc. 121 hours on clock since install in 2009. Runs auto test sequence 1x/week for 20 minutes.
Recent horrendous snowstorm, power out from Tuesday night 7pm 'till Sunday night, then intermittent follow-up outages. Clocked 230 hours straight run time! WOW! Man am I glad I have this setup in place.
Now I've got to install an 8kW genset next door at my 'flip' house, where my friends/tenants suffered through the same storm with no electric and only a gas fired hearth stove to keep them and the pipes from freezing.
Thinking I'll go with a Generac this time, and possibly tie into the 10 switch gentran transfer switch I have in place for what was to be a Craftsman 7.5kW portable, but alas some idiot stole it from my house's garage while the house was for sale. :mur::confused2:
I'm needing to know if VT allows placement of a steel enclosure genset 18" from the garage/house or a greater distance is required. Any answers on that?
Post-tornado, some people on here have had long outages, but that's quite the run for just a snow-event CM !
Obviously, you've had your money's worth out of that setup, already.
Perhaps a VT familiar electrician will stop by, or that might be a good thread-starter question in Rural Living.
Rgds, D.
   / Your last generator Maintenance Run #369
Rgds, D.
Yes, GMP, who took over CVPS a few years back said it was a $10+ million storm before it was even completely cleaned up. I spoke to linemen from Syracuse NY who worked 20 hour days, 3 days in a row fixing the same road, because as soon as they would restore power a branch or tree would collapse from the wet snow. They, GMP said it was worse than the '98 ice storm and worse than Irene as far as extent of damage, how long the cleanup took, and how many crews needed to be called in from other states.
It's a good thing it wasn't -20 in January or the losses would have been major with frozen everything. I've lived in this house since '86 and have never witnessed such devastation. I've got trees of all sizes snapped off all over my 25 acres. It's nutz!!:confused3:
I drove up to Ottawa in '98, while the State of Emergency was in effect. You only have to live through one of those events, to appreciate what havoc Mother Nature can create.
Temperature was bad then, around -40 for quite a stretch. I bought my first gen then, and took it to my sister's place, so they could get their natgas furnace running. After seeing an event like that, I decided I'd never be w/o at least one ready-to-run generator around.
After a big event, it can be a good time to buy a used gen - enough people decide that they'd sooner have the money, than keep a gen around.
Rgds, D.
   / Your last generator Maintenance Run #371
Generac instructions call for 18 " clearance from buildings so if VT. or the local jurisdiction allows then you then yes.. Most brands are not the same though..
   / Your last generator Maintenance Run #372
Questions.... always with the questions..... ;)
E or Efree gas ?
What region of the continent do you buy your fuel in ?
Rgds, D.
Normal NH state pump gas...ethanol, unfortunately.
You're doing well on the Epoison.
You may have no choice state-wide in NH; up here Costco HiTest is Efree.
Rgds, D.
   / Your last generator Maintenance Run #374
Weather reports mentioning possibility of icing & outages over the next day or so, so double checked the old Porter-Cable BSI-550.
The tires were a bit soft so aired them up. Oil OK (middle of range), but looks due for a change. Cranked on third pull, usually only takes 1 but it has probably been 3 months since the last run (got out of the habit while on light duty).
Running with 2 1500w heaters (1 per leg) shows 117v on one leg, 118v on the other, @ 59.6 Hz. Got 55 gallons of long-term treated gas stashed in the storage bunker, so should be good to go...
ETA: Went ahead & took care of the oil change while it was still warm. Old oil dark but no indication of water or metal. Cranked & rechecked - all good.
Nick
Nick
Good to see that you are off the Light-Duty list Nick.
Nice fuel cache. The sweet spot for my portable gens is probably something like 9 or 10 weeks - I don't like to go past 3 months w/o a run.
On air-cooled engines w/o oil filters, once the oil looks darker up top, I want it gone. It's not like these little gens take much oil per change.
Sounds like you are in fine shape again..... that should mean zero grid interruptions in your neighbourhood !
Rgds, D.
   / Your last generator Maintenance Run #376
I recently obtained a Honda EU 2000i that needed repair.
I installed new rings and cleaned the carb and now have a nice, quiet fuel efficient backup in addition to my other units.
After two runs operating a 1hp fan 1 run in eco mode and 1 at full speed for approximately 20 hours to verify reliable operation I installed a donated 6 circuit transfer switch to operate essential circuit’s.
Circuit
A, powers the 1/4hp fan for my wood furnace.
B, powers the oil furnace.
C runs the fridge, stove igniters and 3 outlets in the kitchen.
D operates the 2 small freezers.
E operates the living room TV, computer & pellet stove if needed.
F operates the garage door.
After installing I ran the generator to verify what it could power simultaneously.
I found that when running the 1/4 hp wood furnace motor I needed run the fan motor continuously to prevent the start-up surge, once running it draws 350 watts.
In my first test the generator consumed 2 quarts of fuel in 3-1/2 hours with all circuits on.
After operating this Gem I’m sold on the Honda EU series of generators.
This unit has a fuel pump which enables you to connect an additional fuel supply for greatly extended run times.
I’m now seriously considering the new Honda EU7000i as an auto backup to support my battery backup system. This generator also has fuel injection which eliminates the choke and increases efficiency.
90cummins
   / Your last generator Maintenance Run #377
Honda does make well engineered generators and one of the first to listen to the consumers that desire quiet operation in a small package...
After two runs operating a 1hp fan 1 run in eco mode and 1 at full speed for approximately 20 hours to verify reliable operation I installed a donated 6 circuit transfer switch to operate essential circuit痴.
Circuit
After operating this Gem I知 sold on the Honda EU series of generators.
I知 now seriously considering the new Honda EU7000i as an auto backup to support my battery backup system. This generator also has fuel injection which eliminates the choke and increases efficiency.
90cummins
That's a good score and save 90 !
They have been making great generators for a long time. A friend of mine has a ton of hours on his 3000 watt EU, it's still running great.
Not sure if you have the manual for yours. I noticed in this recent thread from dragoneggs that the recommendation on his 300 was to not use the EcoThrottle setting, until the gen is warmed up.
http://www.tractorbynet.com/forums/honda/329068-honda-generator-battery-operation-question.html
You may know that already, or don't have EcoThrottle on yours.... just thought to mention it as it stuck in my mind when reading that thread.
4Shorts also makes a good point about the fuel shutoff valve, in dragoneggs thread.
Enjoy the 2000, and let us know what deals you find on the 7000.
Rgds, D.
   / Your last generator Maintenance Run #379
Ran my Honda EU200i for about thirty minutes yesterday. It was connected to about 1500 watts worth of roof deicing cable, to give it a nice load. I then changed the oil and put fresh premium gas (no ethanol in the premium here) with stabilizer.
I also changed the oil In My Honda quad and four stroke husqavarna weed wacker. I thought about giving my Honda water pump an oil change while I was at it, but it is buried in the back of the shed.
There's a great Canadian test load for Ya ! Said in my best Don Cherry imitation..... :thumbsup:
Pumps probably aren't too bad.... gas pressure washers seem to have a tough time keeping water out of the sump though. Seems easier to cover off a few small engines, once you get on a roll :cool2:.
Rgds, D.
2437 (A60432)
2437 (A60432)
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
KBH Tender (A61307)
KBH Tender (A61307)
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
1762 (A58375)
1762 (A58375)
