   / Your last generator Maintenance Run
The times can be changed by a service tech. He can plug in a laptop and tweak them
Granted that some/many customers shouldn't be let near a programming panel, but I can see that being a pain. In remote areas, getting somebody to show up for just a service call can be a problem - you know the business economics well... Lots of guys will install.......
I'm a ways off from buying an auto-start system, but when I do go looking at them, I'll be checking for ambient temperature sensors.... it would be less than child's play to design that for extended test runs a low :cold: temp.
Rgds, D.
   / Your last generator Maintenance Run #322
Rgds, D.
for $266.00 you can get slip on heater for oil filter and battery heater. They plug into the 2 yellow power lines from the house panel. 10 mininstall. Self regulating 240 volt heaters. That, and the onboard battery maintainer.... Once a week or once a month cycling is fine
or... In 2 minutes you can reset the auto exercise cycle betwen weekly, biweekly or monthly timer using the onboard electronic touch pad control.
Those heaters are a good option, up north. What wattages are they typically ? Nice being thermostatically controlled.
Rgds, D.
   / Your last generator Maintenance Run #324
Rgds, D.[/QUOTE
Battery 50 watts, 240 v
oil filter 44 watts, 240 volt
   / Your last generator Maintenance Run #326
Just had a power outage this afternoon. Power went off at 3.30pm and I waited for an hour with nothing happening. Started the back up generator and put it on line around 4.30pm. Still running and if I don't get power back I will be shutting it down at around 9.30pm.
Temperature here has moderated quite a bit - it is now +8C and windy, raining - just over a week ago it was around -25C and snow 18" deep.
I am very glad we have the generator - life could be pretty miserable without it.
A little unplanned exercise for your diesel Jim..... I'm thinking you have a decent sized fuel tank on that, it should keep you comfortable for quite a while.
Rgds, D.
   / Your last generator Maintenance Run #328
Hi Dave,
Yes, the fuel tank is a household 250 gallon heating oil tank (in like new condition) sitting on blocks off the ground, inside a purposely built shed - next to the generator shed. I also have clear plastic hose arrangement on the outside of the tank, that shows me how much diesel I actually have in the tank. With the red colouring of the diesel fuel against a white back round makes for easy reading.
Cheers
   / Your last generator Maintenance Run #329
Ooops, I forgot to add this pic.
Nice setup Jim !
Looonnngg run time between fills :thumbsup: .
Rgds, D.
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2014 Sun Coastal 16' Cargo Trailer (A57148)
2014 Sun Coastal...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
84" Skeleton Grapple Bucket (A55272)
84" Skeleton...
John Deere 4820 Forklift (A57453)
John Deere 4820...
