   / Your last generator Maintenance Run
The times can be changed by a service tech. He can plug in a laptop and tweak them
Granted that some/many customers shouldn't be let near a programming panel, but I can see that being a pain. In remote areas, getting somebody to show up for just a service call can be a problem - you know the business economics well... Lots of guys will install.......
I'm a ways off from buying an auto-start system, but when I do go looking at them, I'll be checking for ambient temperature sensors.... it would be less than child's play to design that for extended test runs a low :cold: temp.
Rgds, D.
   / Your last generator Maintenance Run #322
Rgds, D.
for $266.00 you can get slip on heater for oil filter and battery heater. They plug into the 2 yellow power lines from the house panel. 10 mininstall. Self regulating 240 volt heaters. That, and the onboard battery maintainer.... Once a week or once a month cycling is fine
or... In 2 minutes you can reset the auto exercise cycle betwen weekly, biweekly or monthly timer using the onboard electronic touch pad control.
Those heaters are a good option, up north. What wattages are they typically ? Nice being thermostatically controlled.
Rgds, D.
   / Your last generator Maintenance Run #324
Rgds, D.[/QUOTE
Battery 50 watts, 240 v
oil filter 44 watts, 240 volt
   / Your last generator Maintenance Run #326
Just had a power outage this afternoon. Power went off at 3.30pm and I waited for an hour with nothing happening. Started the back up generator and put it on line around 4.30pm. Still running and if I don't get power back I will be shutting it down at around 9.30pm.
Temperature here has moderated quite a bit - it is now +8C and windy, raining - just over a week ago it was around -25C and snow 18" deep.
I am very glad we have the generator - life could be pretty miserable without it.
A little unplanned exercise for your diesel Jim..... I'm thinking you have a decent sized fuel tank on that, it should keep you comfortable for quite a while.
Rgds, D.
   / Your last generator Maintenance Run #328
Hi Dave,
Yes, the fuel tank is a household 250 gallon heating oil tank (in like new condition) sitting on blocks off the ground, inside a purposely built shed - next to the generator shed. I also have clear plastic hose arrangement on the outside of the tank, that shows me how much diesel I actually have in the tank. With the red colouring of the diesel fuel against a white back round makes for easy reading.
Cheers
   / Your last generator Maintenance Run #329
Ooops, I forgot to add this pic.
Nice setup Jim !
Looonnngg run time between fills :thumbsup: .
Rgds, D.
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
UNUSED FUTURE D39 39" MINI HYD TRENCHER (A58376)
UNUSED FUTURE D39...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
9ft Reading Utility Bed Topper (A57453)
9ft Reading...
1 BOTTOM TURN PLOW (A58375)
1 BOTTOM TURN PLOW...
