YM336D Block Heater
/ YM336D Block Heater
Where I park my tractor under the shed is about 75ft from the power source. I went today and bought a 100ft cord which has 12/3 wires in it. I hope this will be heavy enough to handle the 400 watt heater.
/ YM336D Block Heater #22
I finally got around to installing the block heater. I could not believe it when I put the power handle on it came out like it had been installed yesterday instead of 30+ years ago. I think this will be an asset this winter when I'm setting out round bales. <img src="http://www.tractorbynet.com/forums/files/yanmar/441949-ym336d-block-heater-0925151100-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441950-ym336d-block-heater-0925151121-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441951-ym336d-block-heater-0925151121a-jpg"/>
Was that a screw in plug that you removed or a freeze plug. I have not been able to budge mine.
/ YM336D Block Heater #23
100' 12 gauge is good for 14 or 15 amps. Your heater is probably pulling less than 4 amps.
It was a screw in. A gray tractor may have not had antifreeze or rust preventive maintained in it for the past 30+ years. That was my concern but I hadn't thought about the antifreeze aspect.
Thanks for the info. My 14 gauge would have most likely worked. I can always use another cord. Got a good deal in it ($36.00 tax included). Electricity is not my strongest ability.
2020 DRAGON ESP...
(INOP) 2000 FORD E-350 XLT SD 11 PASSENGER VAN (A59823)
(INOP) 2000 FORD...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
Pat's QH and hydraulic top-link.
Pat's QH and...
2018 Deere 323E (A53317)
2018 Deere 323E...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
