YM336D Block Heater
/ YM336D Block Heater
Where I park my tractor under the shed is about 75ft from the power source. I went today and bought a 100ft cord which has 12/3 wires in it. I hope this will be heavy enough to handle the 400 watt heater.
/ YM336D Block Heater #22
I finally got around to installing the block heater. I could not believe it when I put the power handle on it came out like it had been installed yesterday instead of 30+ years ago. I think this will be an asset this winter when I'm setting out round bales. <img src="http://www.tractorbynet.com/forums/files/yanmar/441949-ym336d-block-heater-0925151100-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441950-ym336d-block-heater-0925151121-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441951-ym336d-block-heater-0925151121a-jpg"/>
Was that a screw in plug that you removed or a freeze plug. I have not been able to budge mine.
/ YM336D Block Heater #23
100' 12 gauge is good for 14 or 15 amps. Your heater is probably pulling less than 4 amps.
It was a screw in. A gray tractor may have not had antifreeze or rust preventive maintained in it for the past 30+ years. That was my concern but I hadn't thought about the antifreeze aspect.
Thanks for the info. My 14 gauge would have most likely worked. I can always use another cord. Got a good deal in it ($36.00 tax included). Electricity is not my strongest ability.
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
New Holland 273 Square Baler (A66408)
New Holland 273...
Skid Steer Mounted Bush Hog (A62613)
Skid Steer Mounted...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
