YM336D Block Heater
/ YM336D Block Heater
Where I park my tractor under the shed is about 75ft from the power source. I went today and bought a 100ft cord which has 12/3 wires in it. I hope this will be heavy enough to handle the 400 watt heater.
/ YM336D Block Heater #22
I finally got around to installing the block heater. I could not believe it when I put the power handle on it came out like it had been installed yesterday instead of 30+ years ago. I think this will be an asset this winter when I'm setting out round bales. <img src="http://www.tractorbynet.com/forums/files/yanmar/441949-ym336d-block-heater-0925151100-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441950-ym336d-block-heater-0925151121-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441951-ym336d-block-heater-0925151121a-jpg"/>
Was that a screw in plug that you removed or a freeze plug. I have not been able to budge mine.
/ YM336D Block Heater #23
100' 12 gauge is good for 14 or 15 amps. Your heater is probably pulling less than 4 amps.
It was a screw in. A gray tractor may have not had antifreeze or rust preventive maintained in it for the past 30+ years. That was my concern but I hadn't thought about the antifreeze aspect.
Thanks for the info. My 14 gauge would have most likely worked. I can always use another cord. Got a good deal in it ($36.00 tax included). Electricity is not my strongest ability.
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
40000SFL (A64556)
40000SFL (A64556)
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
16ft. Field Cultivator (A65640)
16ft. Field...
