YM336D Block Heater
/ YM336D Block Heater
Where I park my tractor under the shed is about 75ft from the power source. I went today and bought a 100ft cord which has 12/3 wires in it. I hope this will be heavy enough to handle the 400 watt heater.
/ YM336D Block Heater #22
I finally got around to installing the block heater. I could not believe it when I put the power handle on it came out like it had been installed yesterday instead of 30+ years ago. I think this will be an asset this winter when I'm setting out round bales. <img src="http://www.tractorbynet.com/forums/files/yanmar/441949-ym336d-block-heater-0925151100-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441950-ym336d-block-heater-0925151121-jpg"/><img src="http://www.tractorbynet.com/forums/files/yanmar/441951-ym336d-block-heater-0925151121a-jpg"/>
Was that a screw in plug that you removed or a freeze plug. I have not been able to budge mine.
/ YM336D Block Heater #23
100' 12 gauge is good for 14 or 15 amps. Your heater is probably pulling less than 4 amps.
It was a screw in. A gray tractor may have not had antifreeze or rust preventive maintained in it for the past 30+ years. That was my concern but I hadn't thought about the antifreeze aspect.
Thanks for the info. My 14 gauge would have most likely worked. I can always use another cord. Got a good deal in it ($36.00 tax included). Electricity is not my strongest ability.
(3) New 23X8.5-14 SS tires on 6-lug John Deere compact tractor rims, Coal Valley, IL (A65640)
(3) New 23X8.5-14...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
65' Air Hose Reel (A66408)
65' Air Hose Reel...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
