solar powered system for block heater
   / solar powered system for block heater #11
All my block heaters are 1500 watts. I do have one old magnetic oil pan heater that was 400 watts…..didnt do much. I used it on my old onan generator.
How far away is the tractor stored from a power source?
   / solar powered system for block heater #12
Frost plug heater on my 2400 is 450 watts. Smaller engines don’t usually require 1500 watt heater
   / solar powered system for block heater #13
Glow plugs may not be enough to start his tractor if in a really cold climate. I know at -10 F my Branson struggles to turn over with out block heater plugged in for awhile.
There’s always the old school tarp and torpedo heater plan. If you want safer theres inverter generators. A solar setup would cost thousands of dollars and still require to be turned on an hour or two ahead and not used indefinitely. A couple of deep cycle batteries and one solar panel like most people are probably envisioning is a woefully inadequate setup.
   / solar powered system for block heater #14
The original heat source was build a fire under the oil pan or engine. I have used coals and heated rocks since a little less chance for fire.
   / solar powered system for block heater #15
You could buy a bunch of jumper batteries for what a solar setup would cost. And solar doesn't work worth a dam covered in snow or dark!
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
(2) Heavy Duty Lug Wrench and Cheater Bar (A57454)
(2) Heavy Duty Lug...
402 (A52706)
402 (A52706)
6ft American Flag Metal Rooster (A57454)
6ft American Flag...
DEUTZ MARATHON...
