YM1500 loader capacity
/ YM1500 loader capacity #1
reb
Central Arizona
YM1500D
Does anyone have an idea how much weight a loader on a 1500D can lift? I am considering ordering a generator which weighs about 450# and wonder if I should be looking for a way to unload it from a truck when it arrives.
/ YM1500 loader capacity #2
I would have to believe you have no problem lifting that much weight as long as you had some kind of weight on the back to act as a counterweight. Maybe have the tiller hooked up.
/ YM1500 loader capacity #3
I pulled a Chevelle V-8 engine with transmission (500-600 #'s ??) using a YM1401D loader. I just had my son sit on the box scraper for extra ballast. Most the loaders I get will lift 800-1000lbs, but will pick up the back of the tractor if you don't have ballast.
Thanks, Jim and Durbob. Maybe I can convince the wife to be ballast if the box blade is not enough. /forums/images/graemlins/grin.gif
/ YM1500 loader capacity #5
Put a 55gal drum in the loader bucket and fill it with water. This will be a 458 pound test. Try to keep on level ground, bucket as low as posible, Etc.
You can also add weight to the rear if needed, by hanging/ hooking heavy objects onto the boxblade, or other attachments.
This will give you a "feel" for the capabilities, your's and the tractor's, before the actual need arises.
Lloyd
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
213088 (A64276)
213088 (A64276)
Adams Weight Hopper (A63688)
Adams Weight...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
