YM1500 loader capacity
/ YM1500 loader capacity #1
reb
Central Arizona
YM1500D
Does anyone have an idea how much weight a loader on a 1500D can lift? I am considering ordering a generator which weighs about 450# and wonder if I should be looking for a way to unload it from a truck when it arrives.
/ YM1500 loader capacity #2
I would have to believe you have no problem lifting that much weight as long as you had some kind of weight on the back to act as a counterweight. Maybe have the tiller hooked up.
/ YM1500 loader capacity #3
I pulled a Chevelle V-8 engine with transmission (500-600 #'s ??) using a YM1401D loader. I just had my son sit on the box scraper for extra ballast. Most the loaders I get will lift 800-1000lbs, but will pick up the back of the tractor if you don't have ballast.
Thanks, Jim and Durbob. Maybe I can convince the wife to be ballast if the box blade is not enough. /forums/images/graemlins/grin.gif
/ YM1500 loader capacity #5
Put a 55gal drum in the loader bucket and fill it with water. This will be a 458 pound test. Try to keep on level ground, bucket as low as posible, Etc.
You can also add weight to the rear if needed, by hanging/ hooking heavy objects onto the boxblade, or other attachments.
This will give you a "feel" for the capabilities, your's and the tractor's, before the actual need arises.
Lloyd
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
EZ Trail 3400 (A63688)
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
