ym 2210
/ ym 2210 #1
YanmarEd
Its on CL cheap says it ran out of fuel what kind of problems can that cause other than having to reprime fuel systym
/ ym 2210 #2
I would be suspect... why did the seller not reprime the tractor? I would take the time to inspect and reprime the engine before purchasing. If he baulks at the idea then more might be wrong. I have had good luck with CL but I am careful. Good luck!!
/ ym 2210 #3
what kind of problems can that cause other than having to reprime fuel system
None. Maybe a dead battery from cranking it, worst case.
Reprime: Open/bleed/close each bleeder screw in sequence: 1) fuel filter inlet, 2) outlet, 3) then the one down on the injector pump inlet. No need to bleed beyond the injector pump.
Like Mully said if the seller won't cooperate - run away. It's not tractor, its a lawn ornament.
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
Lift (A64553)
Lift (A64553)
PORTA POTTY (A67714)
2010 John Deere 4720 (A64911)
2010 John Deere...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
