ym 2210
/ ym 2210 #1
YanmarEd
Its on CL cheap says it ran out of fuel what kind of problems can that cause other than having to reprime fuel systym
/ ym 2210 #2
I would be suspect... why did the seller not reprime the tractor? I would take the time to inspect and reprime the engine before purchasing. If he baulks at the idea then more might be wrong. I have had good luck with CL but I am careful. Good luck!!
/ ym 2210 #3
what kind of problems can that cause other than having to reprime fuel system
None. Maybe a dead battery from cranking it, worst case.
Reprime: Open/bleed/close each bleeder screw in sequence: 1) fuel filter inlet, 2) outlet, 3) then the one down on the injector pump inlet. No need to bleed beyond the injector pump.
Like Mully said if the seller won't cooperate - run away. It's not tractor, its a lawn ornament.
Land Pride RB3584 3-Pt Blade (A66408)
Land Pride RB3584...
2022 EZ-GO ELITE...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
3ft Metal Chevrolet Tailgate (A65583)
3ft Metal...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
