ym 2210
/ ym 2210 #1
YanmarEd
Its on CL cheap says it ran out of fuel what kind of problems can that cause other than having to reprime fuel systym
/ ym 2210 #2
I would be suspect... why did the seller not reprime the tractor? I would take the time to inspect and reprime the engine before purchasing. If he baulks at the idea then more might be wrong. I have had good luck with CL but I am careful. Good luck!!
/ ym 2210 #3
what kind of problems can that cause other than having to reprime fuel system
None. Maybe a dead battery from cranking it, worst case.
Reprime: Open/bleed/close each bleeder screw in sequence: 1) fuel filter inlet, 2) outlet, 3) then the one down on the injector pump inlet. No need to bleed beyond the injector pump.
Like Mully said if the seller won't cooperate - run away. It's not tractor, its a lawn ornament.
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
KUBOTA M108S TRACTOR (A64277)
KUBOTA M108S...
2015 TROXELL 130BBL VACUUM TRAILER (A65643)
2015 TROXELL...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
