ym 2210
/ ym 2210 #1
YanmarEd
Its on CL cheap says it ran out of fuel what kind of problems can that cause other than having to reprime fuel systym
/ ym 2210 #2
I would be suspect... why did the seller not reprime the tractor? I would take the time to inspect and reprime the engine before purchasing. If he baulks at the idea then more might be wrong. I have had good luck with CL but I am careful. Good luck!!
/ ym 2210 #3
what kind of problems can that cause other than having to reprime fuel system
None. Maybe a dead battery from cranking it, worst case.
Reprime: Open/bleed/close each bleeder screw in sequence: 1) fuel filter inlet, 2) outlet, 3) then the one down on the injector pump inlet. No need to bleed beyond the injector pump.
Like Mully said if the seller won't cooperate - run away. It's not tractor, its a lawn ornament.
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
2014 Chevrolet Impala Limited Sedan (A66738)
2014 Chevrolet...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
1457 (A65054)
1457 (A65054)
2012 CTS BELLY DUMP (A67714)
2012 CTS BELLY...
