YFL 155 float valve operation
/ YFL 155 float valve operation #1
Strahwberry
YM155D
Hi all,
I have a question, and I tried my best goggle-fu skills and couldn't find an answer.
As you know, I'm brand new to tractors. This question feels a little obvious.
How do you engage the float function on a YFL 155, with what is probably an original loader valve control?
Thanks!
Jon
/ YFL 155 float valve operation #2
Some valves don't have a float position but, if it does, you just move the lever beyond the normal lower position. Push the lever to lower the bucket and then you would just push it a little more and it should go from 'power down' to a float. Normally there is a detent there to hold the valve in that position. Some valves don't have a float. Some have it only on the lower position. Some also have it on the dump position.
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2018 RAM 2500 (A65643)
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
Rotomec PHD 300 (A64126)
Rotomec PHD 300...
