Yanmar 2310
/ Yanmar 2310 #1
rorygeorge
Sonoita,AZ
Yanmar 2210
I have a Yanmar 4x4 tractor and first the 4x4 quit working then the three pt hitch quit working. What's up? I check the screen and it was clean, reservoir level correct. What else could be happening. Thanks Rory
/ Yanmar 2310 #2
There is almost no way the 2 could be linked. I think you are looking at 2 completely different problems that you need to troubleshoot independently. Are there any other symptoms? Do you have a loader on it?
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ Yanmar 2310
Aaron, yes it has a loader and it is working fine. ?
/ Yanmar 2310 #4
The only "link", if there is one, would not likely be mechanical, but rather the source of the tractor; otherwise it is a random coincidence. Is this a recent purchase? Does the seller claim to be a "dealer"?
/ Yanmar 2310
I bought the tractor from and individual who bought several to make some money. He was selling out and moved back to Texas so there is no local dealer to question. I purchased it a year ago with all new implements etc and everything worked fine.
/ Yanmar 2310 #6
First check the control valve/3 point sensing linkage. Next would be trouble shooting the control valve & lift cylinder. It would be helpful to know how the loader is plumbed. 2 hose or power beyond?
/ Yanmar 2310 #7
Is this a YM2310? In your other posts it says you have a YM2210. Big difference between the two.
Does your 4wd lever move without resistance?
Buck
/ Yanmar 2310
The tractor is a YM2210BD sorry for the confusion. It has two hoses to the bucket for lifting and two for tilting. 4x4 lever move freely. Thanks
/ Yanmar 2310 #9
What he meant when he said that the he needed to know how the loader was plumbed is number of lines beyond the 4 to the loader. Are there 2 (6 lines total) or 3 (7 lines total).
Tackle the problems one at a time--you have a good tractor and if it ran for a year without problems then it can probably be fixed to run many more. You have several very good dealers helping you in this thread.
Mike
/ Yanmar 2310
The tractor has 6 hoses coming off the pump. Does that help?
/ Yanmar 2310
Aaron, I'll have to get back to you next week. I'm not where I can look at it closer until then. Do you know of a mechanic in AZ if I can't solve the mystery?
/ Yanmar 2310
I'll post some pics. Email sent to Aaron.
/ Yanmar 2310
I'm still have 3pt problems. Anyone out there have a suggestion? Thanks!
/ Yanmar 2310
IT looks like the 2210 is on the mend. Ujoint problem was the 4x4 culprit, control valve for the 3pt. Thanks for the help.
/ Yanmar 2310 #17
Say if you look at your last picture it shows a backwards hook that sticks up from the back of the tractor behind the seat. What is that used for? I always thought maybe it was to hold the toplink but it is backwards? Are we missing something?
/ Yanmar 2310 #19
Thanks California but how does it work? I don't see how it can vent?
Is that hook hollow? I never noticed.. I will check mine out....
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft. Insulated Bucket Truck (A66736)
2012 Freightliner...
2006 KENWORTH T800 TRIAXLE (INOPERABLE) (A67714)
2006 KENWORTH T800...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
CAT J600/375L Teeth (8) (A68134)
CAT J600/375L...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
