Yanmar 2310
/ Yanmar 2310 #1
rorygeorge
Sonoita,AZ
Yanmar 2210
I have a Yanmar 4x4 tractor and first the 4x4 quit working then the three pt hitch quit working. What's up? I check the screen and it was clean, reservoir level correct. What else could be happening. Thanks Rory
/ Yanmar 2310 #2
There is almost no way the 2 could be linked. I think you are looking at 2 completely different problems that you need to troubleshoot independently. Are there any other symptoms? Do you have a loader on it?
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ Yanmar 2310
Aaron, yes it has a loader and it is working fine. ?
/ Yanmar 2310 #4
The only "link", if there is one, would not likely be mechanical, but rather the source of the tractor; otherwise it is a random coincidence. Is this a recent purchase? Does the seller claim to be a "dealer"?
/ Yanmar 2310
I bought the tractor from and individual who bought several to make some money. He was selling out and moved back to Texas so there is no local dealer to question. I purchased it a year ago with all new implements etc and everything worked fine.
/ Yanmar 2310 #6
First check the control valve/3 point sensing linkage. Next would be trouble shooting the control valve & lift cylinder. It would be helpful to know how the loader is plumbed. 2 hose or power beyond?
/ Yanmar 2310 #7
Is this a YM2310? In your other posts it says you have a YM2210. Big difference between the two.
Does your 4wd lever move without resistance?
Buck
/ Yanmar 2310
The tractor is a YM2210BD sorry for the confusion. It has two hoses to the bucket for lifting and two for tilting. 4x4 lever move freely. Thanks
/ Yanmar 2310 #9
What he meant when he said that the he needed to know how the loader was plumbed is number of lines beyond the 4 to the loader. Are there 2 (6 lines total) or 3 (7 lines total).
Tackle the problems one at a time--you have a good tractor and if it ran for a year without problems then it can probably be fixed to run many more. You have several very good dealers helping you in this thread.
Mike
/ Yanmar 2310
The tractor has 6 hoses coming off the pump. Does that help?
/ Yanmar 2310
Aaron, I'll have to get back to you next week. I'm not where I can look at it closer until then. Do you know of a mechanic in AZ if I can't solve the mystery?
/ Yanmar 2310
I'll post some pics. Email sent to Aaron.
/ Yanmar 2310
I'm still have 3pt problems. Anyone out there have a suggestion? Thanks!
/ Yanmar 2310
IT looks like the 2210 is on the mend. Ujoint problem was the 4x4 culprit, control valve for the 3pt. Thanks for the help.
/ Yanmar 2310 #17
Say if you look at your last picture it shows a backwards hook that sticks up from the back of the tractor behind the seat. What is that used for? I always thought maybe it was to hold the toplink but it is backwards? Are we missing something?
/ Yanmar 2310 #19
Thanks California but how does it work? I don't see how it can vent?
Is that hook hollow? I never noticed.. I will check mine out....
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
2015 Ford F-250 Knapheide Service Truck (A66736)
2015 Ford F-250...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
Unused 2021 Tufline BCP2416 8ft. Cultipacker Tractor Attachment (A66734)
Unused 2021...
Unused 2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
Unused 2023 USA...
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2010 Ford F-150...
