yanmar 2000 won't start
/ yanmar 2000 won't start #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
I've had my 2000 a little over a year now and never had any problems. it has always smoked some but not to bad. anyway I lent it to a friend and he called to say it wouldn't start. it had been working great he turned it off and went inside for an hour, came back out and it turns over but won't fire up. he was able to pull start it with his truck. I've got it back home now and it just won't start. it turns over plenty fast enough and had fuel every where. I did try a little starting fluid and it ran fine although it does smoke more than before. I turned it off and waited about 30 sec. and it started back up fine. but after an hour of sitting it won't start again.
if anyones got ideas I'd sure appreciate hearing them.
thanks
mark
/ yanmar 2000 won't start #2
Put a new Fuel Filter in it and bleed the lines.And it may have some bad Fuel in it too.
thanks for the help.
I did try a new filter still no luck.
mark
/ yanmar 2000 won't start #4
fuel
air
compression
That's all there is. If fuel is clean and not blocked, and it ran when pull started (which does not increase air flow) that leaves compression. Might be time for rings.
that was my guess. Ive never built a diesel so I'm a little worried about tearing into this. how do you do a compresion test on these. since there is no spark plug, do you pull an injector? also are there any shop manuals available? I'm the type of person that if i've got good instructions I can do most anything.
any way thanks for the reply
mark
/ yanmar 2000 won't start #6
I bet if you pull the head and look at the rings, you'll easily see the problem. PM me your email address and I'll send you pictures of old rings and new rings in the cylinder of my 1700.
/ yanmar 2000 won't start #7
LMTC said:
If fuel is clean and not blocked, and it ran when pull started (which does not increase air flow) that leaves compression. Might be time for rings.[/QUOTE
My thoughts exactly.
/ yanmar 2000 won't start #8
DARN!! I really hate to hear that.......Hope you get it fixed soon........Please keep us posted on it.
Travis R
/ yanmar 2000 won't start #9
mark
Can we assume you bled the fuel lines properly, assured no water in the fuel, and checked the air filter and muffler? Don't know what you mean by "fuel everywhere", but if the above checks out, you need to check the injector spray pattern.
what do you check on the muffler? exhaust does come out when started so it's not plugged. also I'm not sure how to check the spray pattern on the injector.
thanks mark
/ yanmar 2000 won't start #11
Try looking inside the fuel tank for sediment, slime, ect.. sometimes it will settle to the bottom of the tank in an hour and block the fuel line.
I would drain the tank clean it out & start over with fresh fuel. All that can be done without removing it, then move to the fuel lines for inspection.
Then check the fuel filter again (yes again) and bleed it.
Bleed the injector pump, and see if it will start.
Ernie's Imports
well great idea's but the fuel tank is less than a month old, I will however dump the remaining fuel and start from scratch, and put in a new fuel filter. but all this will need to wait a week as my son has a archery bull elk tag and I need to scout for him. he is in oregon at college and he was drawn for elk here in AZ. I will keep you all posted on what I find an again thanks for all the help and great idea's.
mark
/ yanmar 2000 won't start #13
Please don't use starting fluid. It can be really bad stuff for a small diesel.
/ yanmar 2000 won't start #14
You mean like busted pistons, or bent rods? I just replaced 2 pistons in a YM2000 that a guy used ( a little bit ) of starting fluid.
Danny
ok thanks----no starting fluid don't want to make things worse!!!
/ yanmar 2000 won't start #17
Danny
Good luck runningbird with tractor and the elk hunt.
Danny I wish I would have read this post a week ago.
I just posted on parts and repair.
/ yanmar 2000 won't start #18
gclark94560 said:
Hi All!
New member Greg Clark here. YM2000 new owner.
I need a fuel filter - I want one I can get at the auto parts store. Any help? :)
Thanks!
Greg
Contact Wayne at Little Miami Trading Company or Hoye tractor. I don't believe you can get it at an auto parts store??
/ yanmar 2000 won't start #19
gclark94560 said:
Hi All!
Thanks!
Greg
If you're in Alabama, you can get it at Fredricks Equipment > Home in Hartselle, Al.
/ yanmar 2000 won't start #20
i buy all my parts from hoyetractor.com Very extensive parts list, buy online, and good service. I'm not sure about sourcing such from local stores, i haven't tried...
about starting, yea, startig fluid is a big no-no. causes an explosion in the engine... you might try other things like more heat, more air... and if you are crazy like me, when it's down to like 10F (ah, them days are coming..) i've used propane towards the intake manifold... yeah, flame propane.. anyway, that's probably not your problem and i'm starting to ramble...
stay away from starter fluid and ether...
207279 (A52708)
207279 (A52708)
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2012 Landoll 4731-33 Vertical Tillage Tool (A63116)
2012 Landoll...
2016 POLARIS RANGER 900 UTV (A64047)
2016 POLARIS...
