Winterize Power Washer Pump ?
/ Winterize Power Washer Pump ? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
My friends and coworkers all insist that a power washer pump must be filled with anti-freeze for the winter (Michigan) to prevent the pump from freezing and breaking the seals. They say that there is no way to drain all the water out of the pump.
I would like to use my power washer all winter long to clean the road-mud off the cars. Filling it with anti-freeze after each use is just not practical.
Any thoughts?
/ Winterize Power Washer Pump ? #2
With mine I attach a short section (2 foot) of garden hose to the water inlet and fill it with antifreeze. Pull the rope starter a few times to draw it into the pump. Then I put the soap siphon tube into the bottle of antifreeze and pull the rope a few more times. It only takes five minutes to do and I have never had a problem.
/ Winterize Power Washer Pump ? #3
Jerry,
Only 2. And one is kinda obvious. Keep it in a place that stays above 32 deg. Or maybe blow it out with compressed air, idle it way down for this maneuver. The former will certainly work. The latter probably will work.
Nick
/ Winterize Power Washer Pump ? #4
Sears sells a product called Pump Saver for this purpose.
My first winter I thought I had all the water out but come spring found the pump had cracked due to water freezing ($159) so now I haul the power washer to the basement, as the garage is not heated.
PJ
/ Winterize Power Washer Pump ? #5
Last winter was the first with my power washer. I keep it in the unheated barn. I used the same technique as Logan but I used windshield washer fluid (good down to -20 or so the jug says).
Ok, thanks for the tips on winterizing. I am trying to figure out a way that I can use the washer all winter long. I have thought of wrapping the pump with heat tape and keeping it plugged in all the time (you know, the kind of stuff you wrap pipes with to keep them from freezing). I also thought of maybe aiming a heat lamp at the pump. Another idea I had was to build a closet along the wall that connects the garage to my house and steal a little heat from the house to keep the closet warm. The closet idea will allow me to keep the washer and hoses ready to go at all times. Filling the machine with antifreeze once a week or so when I use it would just be too much hassle.
Ok, any thoughts on this?
/ Winterize Power Washer Pump ? #7
I use the pump saver. It costs about $7.00 a can, and I get 3-4 applications from a can. It clears out of the washer in about just a few seconds. The washer also is kept in a heated part of my garage that was formally a mother-in-law type apartment. The pump saver also is supposed to provide lubrication to the pump when the washer is not used or a couple of months.
This is the picture from the sears web site for the Craftsman Pump Saver. Can anyone explain what I'm seeing in this picture and how it works?
/ Winterize Power Washer Pump ? #9
I will probably only get 1 application from my can (which is OK as I would lose it before next year anyway), but I put it away without winterizing as I was planning on using it again and turns out that won't happen. The wand and pressure hose were still attached. The way I had it put away I couldn't get the hose off, but I could at least manage to get the can connected to the inlet. I just hit the valve on the can and hit the wand and let it push all of the water out of the hose as well. Hadn't thought about getting the water out of it as well as this is my first year for it. May have used a little more antifreeze but at least I know everything is protected including the wand.
/ Winterize Power Washer Pump ? #10
Jerry
I run RV antifreeze through my pressure washer. I pour 2 gallons into a 5-gallon bucket. Put suction hose in to bucket, Start washer and with wand in bucket run the antifreeze until pink comes out of wand. This can be done several times over the winter until antifreeze is diluted with water and a new bottle of antifreeze is needed.
My pressure washer is over 10 years old with no problems.
/ Winterize Power Washer Pump ? #11
I have an industrial electric pressure washer. The hoses are all quick connect fittings. I
use it at least weekly & on many occasions several times a weak. I keep it in an unheated
garage. I disconnect the wand from the hose & hang it on the wall with the trigger open
so that the wand drains. This is especially important because trapped water wil crack the
trigger. I used to do as the others with the windshield washer fluid. Now, I disconnect
all hoses & flip the switch on for a few seconds to get all the water out. What's left
doesn't hurt anything. I have been doing this for the last several years. Seems to me, thee
stuff from Sears would get a bit pricey over the winter. When I had the smaller Sears
electric washer, I carried it in the basement after using it in the winter.
/ Winterize Power Washer Pump ? #12
I do just like Logan-- 2 ft piece of hose -- fill w/ antifreeze-- pull rope til AF comes out other side-- takes about two minutes. And I use it at times durung winter, too. A couple of minutes is way cheaper than broken pump! This is here in frozen ND. Don
Well, here's my solution. I took out the four bolts holding the pump to the engine and slid the pump off the shaft. The pump is now safely stowed in the basement and I can bolt it on or off in about 2 or 3 minutes.
I got this idea because a friend of mine takes his entire unit in the basement for the winter. I won't consider putting an item with a gas tank in the basement and my friend can't be convinced its a bad idea. My solution puts the pump where it belongs and keeps the engine and fuel where it belongs, outdoors. Thanks for all the tips.
/ Winterize Power Washer Pump ? #14
Mrwurm,
What did you decide to do regarding your power washer in winter use?
Your comment about not wanting to put anti-feeze in and still use during the winter would suggest storing in warm area (basement?) would be best solution.
PJ
Paul, I did some power washing last week when it was 28 degrees outside... /w3tcompact/icons/hmm.gif
I think I have decided that I don't need to use it in the winter time. /w3tcompact/icons/blush.gif
I'll just pay for a car wash and stay warm and dry. /w3tcompact/icons/eyes.gif
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
2000 FREIGHTLINER CENTURY CLASS DUMP TRUCK (INOPERABLE) (A67714)
2000 FREIGHTLINER...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
2019 INTERNATIONAL DURASTAR 4300 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
PALLET OF ALUMINUM PIPING (A68842)
PALLET OF ALUMINUM...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
