Will this mixture freeze
/ Will this mixture freeze #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am in LA, maybe for a while. I just realized my sprayer is 1/4 full of Crossbow mix (it has surficant as well). Just wondering if the Crossbow will lower the freezepoint. I usually put in some non freeze stuff but as I left the farm in September...
We don't get too cold where I live. usually 35 during the day at the lowest, and 20 at night and only for short stretches. But as the weather is no longer predictable.... Last year we had no freezing days, the year before, way to many.
Anyone have an insight on Crossbow?
/ Will this mixture freeze #3
I live up the road (Longview) from you and had we met for coffee a couple a years ago like we almost did I say that I'd go drain your tank but since we didn't meet, I wouldn't let me near your place cause you realy don't know me! I'm at 800 ft and have never had any trouble with my sprayer. Don't worry about it till january at least. You could mix up a liter bottle of the stuff and put it in the freezer and see what happens! Good luck!
/ Will this mixture freeze #4
Most folks' freezers are at around 0 degrees Fahrenheit or below, so if it doesn't freeze in there, you're probably good to go. But if it does freeze, you may still be good to go, since most folks talking about a "freeze" outdoors are referring to 32 F. PS: If you go putting Crossbow in your fridge, make sure you seal it up well and clean it off. I wouldn't want that stuff getting on my food.
/ Will this mixture freeze #5
/ Will this mixture freeze #6
I live in AL with a very similar climate. I think that you mixture will freeze, and I would either empty it or add RV antifreeze to your Crossbow. This should be sufficient to keep it liquid.
2022 EZ-GO ELITE...
generator trailer (A61569)
generator trailer...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
