WICKED Toothbar will Transform Your Bucket
/ WICKED Toothbar will Transform Your Bucket #61
If you put just a slight bend in the buckets cut'n edge, the wicked tooth bars wedges REALLY holds the tooth bar tight... :)
/ WICKED Toothbar will Transform Your Bucket #62
OR like happened with my DIY bar, heat from welding the teeth holders curved my tooth bar so it is slightly more than tight fit.
/ WICKED Toothbar will Transform Your Bucket #64
BXPANDED bends their cutting edge in a jig prior to welding on the clips so straight after welding. Bend varies on length and number of clips.
Common technique in fabrication.
I just love Wicked feedback!!
Travis
Some real Wicked diggin out in the wild.. #EAfamilyROCKS
Travis
/ WICKED Toothbar will Transform Your Bucket #67
On the wicked tooth bar if you bust a
tooth do you need to check in with the
dentist????? :oops:
willy
dentist????? :oops:
willy
If you do something on a tractor to bust a Wicked tooth, you'll probably need more than dental work.. 💥 :ROFLMAO:
We tried to break er...
Travis
/ WICKED Toothbar will Transform Your Bucket #71
Ted etal, can you make me a smooth edge? I have a little Yanmar with a 4' wide bucket that needs a cutting edge. It has no mounting hole so no need for custom lay out. I would want smooth for driveway grading and snow scraping etc. Thanks!
We have made a few Wicked Toothbars with a smooth edge. It would be the same price as the serrated, and you'd simply install with the two side ears.
Travis
I just love seeing fresh Wicked Toothbar feedback!
...and how bout the mention of FAST SHIPPING?!?!?
Travis
I stumbled upon some more Wicked good stuff!!
Travis
/ WICKED Toothbar will Transform Your Bucket #75
I'm thinking about ordering a Wicked Toothbar for my Kioti CX2510h. I would like it delivered along with my other order this coming June. I hope it wouldn't be a pain adding onto an existing order.
The bucket on my KL2510 Loader is just downright weird. Not only are the sides of the bucket sort of Ski Jump shaped, concave if you will, but Kioti decided to put a big honkin' brace on the bottom outside edge. So the ears, I think, would have to be longer than usual. I think. I really don't want to have to punch through an extra 10mm (??) of hardened steel if I don't have to.
Next time you build one for a Kioti KL2510 loader, maybe you could let me know somehow or another. In here would be fine.
Thanks
R
I can take a couple pics of the wicked tooth bar on my CX2510 bucket tomorrow if you want to check out the fitment.
/ WICKED Toothbar will Transform Your Bucket #77
The day I installed the tooth bar...
Up close of the tabs on the bucket. The bolts that come with the tooth bar are probably an inch and a half longer than necessary. I replaced them with shorter bolts. But as you can see there's just enough room to clear that re-enforcement bar. Also, the holes in the attachment ears on the tooth bar are elongated to allow some front to back adjustment. Here are my measurement notes from my order. CX2510 Kioti USSQA Std hoses and couplers ID 49 5/16 EDGE 1/2 OD 49 3/4.
View attachment 737901View attachment 737902
View attachment 737903View attachment 737904
Looks like she fits like a Wicked glove!! Thanks for sharing. #EAcustomersROCK
Travis
We just received some more Wicked good feedback in the EA Channel Group(join us).
The Wicked Toothbar continues to impress and ship surprisingly fast!!
Travis
I showed off LOTS of Wickedness in my Factory Stroll video this morning!
Let me know what you think!!
Travis
2022 EZ-GO ELITE...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
KOMATSU PC 200 EXCAVATOR (A65643)
KOMATSU PC 200...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2007 KENWORTH (INOPERABLE) T880 (A65643)
2007 KENWORTH...
