Which size BB for 955
/ Which size BB for 955 #1
onthehill
I'm looking to purchase a BB this week for my 955. I've looked at a bunch of threads but I can't figure out if I should be getting a 5ft or 6ft BB. I was leaning towards a 5ft blade. Does that sound about right?
Thanks.
/ Which size BB for 955 #2
Sounds right, as long as it reaches the outside width of your rear tires.
/ Which size BB for 955 #3
What did you end up with? I just bought a 5' used BB for my 955 and wanted something that would cover the 5' width of the rear tires. I was concerned I wouldn't have enough power/traction for anything larger (I have turf tires). Wondering how it worked out for you? I've attempted to attach a photo...
/ Which size BB for 955 #4
For me and the type of ground I use it on, the 60" is just right. I have R1s set in the wide position.
/ Which size BB for 955 #5
60" is what I use on my 855; works well there also.
/ Which size BB for 955 #6
I agree. The 955 could handle the 6ft blade but the 5ft will be more manueverable. I had a 6ft on my 2720 for a short while as it was left over from my Ford 9N. It was a bit unweildy. I sold it and got a 5 foot and am much happier.
The only thing you need to ask yourself is do you plow a lot with the blade angled? If so, you want the blade to still cover the width of the tires while angled and you might need a 6ft blade to do that.
/ Which size BB for 955 #7
Since box blades don't angle, the point is moot.
For my grader blade, I went 6ft though I wanted 5ft, I got the 6 for the same price as they didn't have the 5ft in stock when I got there (they said they did earlier). Having gotten 6ft I am glad of it. Did the same when buying a landscape rake so I can angle them fully and have my tread path covered.
2009 IC Corporation School Bus, VIN # 4DRBUAAN19B694286 (A65563)
2009 IC...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
Farm King 300 bu Gravity Wagon (A66408)
Farm King 300 bu...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
