Which engine would you choose?
/ Which engine would you choose? #1
Zebra5
Looking at 5XXX JD Tractors. Of these engines which would you choose/avoid? 5320 3 cyl turbo, 5420 4 cyl, 5425 4 cyl turbo, 5325 5 cyl turbo.
Was the 3 cyl turbo discontinued because of problems? Or is it now in the smaller 50X5E series?
Wet sleeve vs dry, any thoughts?
/ Which engine would you choose? #2
I prefer the higher number of cylinders but would definitely wan't the wet sleeve design. The wet sleeved motors mean you can replace the sleeves (or liners with piston and rings) and renew the motor. The dry sleeved engines are cheaper in most cases.
I prefer planetary final drives which start with the 4000 series and up, and wet sleeved motors which start with the 5000 series today. The older tractors such as my 820 had planetary final drives and wet sleeves even though it is a much lower hp tractor.
/ Which engine would you choose? #3
I think if you do some digging on the 5-cylinder, there's some disappointment with the fuel usage.
Haven't read anything negative about performance or longevity, though.
AKfish
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
2018 CHEVROLET 3500 SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2023 Kubota KX057-5 Midi Excavator (A66734)
2023 Kubota...
2014 Ford Focus Hatchback (A66738)
2014 Ford Focus...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A68183)
1987 Polar 307 SS...
