Which backhoe for B3030?
/ Which backhoe for B3030? #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
OK, so I'm doing my research for my next machine. I'm trying to decide which backhoe I should get with a B3030.
Has anyone put a Woods BH80X backhoe on a B3030 yet? The Kubota BH75 specs out right between the Woods BH70X and BH80X. Two things I really like about the Woods hoes are the curved boom and the thumb option. I was really leaning toward the Woods BH80X, but the dealer mentioned that he thought that hoe might be a bit much for the 3030. As much as I'd like the thumb, if it were to come down to the BH70X vs the BH75, I'd have a tougher time deciding, because the BH75 is a bit bigger and more powerful.
The dealer also recommended the aux. hyd. pump kit if I went with one of the Woods hoes. - Would the pump kit really make that big of a difference in performance over tapping into the tractor hydraulics? I think, although he quoted an $1150 charge for adding rear remotes, it makes sense to have the remotes for other potential future needs. Even if I were to have the rear remotes installed, would it benefit me at all to go ahead and get the Woods pump kit for performance reasons?
/ Which backhoe for B3030? #2
I may not be totally following your discussion regarding the rear remotes. The BH75 does not run off the B3030 rear remote option. It is driven from a hydraulic feed located at/near the rear of the tractor. I believe this hydraulic port is standard with the tractor, unless the cost is buried in the cost of the BH75.
I have been more than happy with the performance of the BH75. Speed and break away force seem well matched to the tractor (power and weight). I agree the thumb would be nice to have.
</font><font color="blue" class="small">( I may not be totally following your discussion regarding the rear remotes. The BH75 does not run off the B3030 rear remote option. It is driven from a hydraulic feed located at/near the rear of the tractor. I believe this hydraulic port is standard with the tractor, unless the cost is buried in the cost of the BH75.)</font>
That's interesting - I was under the impression that you needed to add rear remotes for any hydraulic rear implement. However, according to this particular dealer, I would need to add the rear remotes to use the tractor hydraulics with the Woods hoe.
I guess what I'm wondering about your statement is whether or not the B3030 comes with the hydraulic fittings like the BX22/23 have - I wouldn't think that would be the case, since it isn't sold as a 'TLB'. I guess I need to go take a close look at a B3030 or 2630 on the lot and see what I can find.
Sounds like there aren't too many B3030 owners who've looked into the BH75 vs the 2 new Woods hoes. I've only seen TBNers with B2630 & B3030 with BH75 backhoes, so I may not get much help here.
/ Which backhoe for B3030? #4
The hydraulic feed is not standard with tractor, only when BH is installed...atleast that has been the case with the two Kubotas I've had (B7500, L2800).
/ Which backhoe for B3030? #5
Looking through the Kubota B series specs it looks like the front and rear hydraulic outlets are standard on the B3030 and on the B7510DTN tractors, front outlet only on the remaining B7500s and the B7800. So that would seem to agree with your thoughts for the B7800.
It looks like the quick disconnects, hoses and fittings for the BH75 connection to the tractor hydraulics must come with the BH. But you don't need the rear remotes installed to use the BH75. When I get a chance I'll look at the assembly documents for the BH75 that I got from the dealer. It should show what comes with the BH.
/ Which backhoe for B3030? #6
</font><font color="blueclass=small">( Looking through the Kubota B series specs it looks like the front and rear hydraulic outlets are standard on the B3030 and on the B7510DTN tractors, front outlet only on the remaining B7500s and the B7800. So that would seem to agree with your thoughts for the B7800.
It looks like the quick disconnects, hoses and fittings for the BH75 connection to the tractor hydraulics must come with the BH. But you don't need the rear remotes installed to use the BH75. When I get a chance I'll look at the assembly documents for the BH75 that I got from the dealer. It should show what comes with the BH. )</font>
Depends on what you mean by "rear remotes standard". NEITHER front OR rear are "standard"...because whichever is included in the costs of any attachment. I have front..because I bought mine with an FEL... It has no "rear". The costs of adding rear ( a simple plate removeal and adding the "kit" was quoted me at $550.)
Ive checked into the backhoes and ..for me..I want the PTO driven model to keep the HYD systems SEPERATE..and the PTO pump is right at $150 MORE than the rear hyd system setup.
Since on mine ( this is a future purchase for me) I'll be running a LOT MORE hours on the rest of the tractor than the BH will ever see...I dont need to be swapping out ALL the fuild each time..which I would have to do if the systems were connected.
EDIT: I said loaders..and mean backhoes.
</font><font color="blue" class="small">( Ive checked into the loaders and ..for me..I want the PTO driven model to keep the HYD systems SEPERATE..and the PTO pump is right at $150 MORE than the rear hyd system setup.)</font>
Did you mean to say you've checked into the BACKHOES, rather than loaders, and that you'd rather have the separate PTO driven hyd pump for the backhoe? That way, you're changing tractor hyd fluid, and backhoe hyd fluid separately. How much hyd fluid does the Woods hoe hold, how much does the B3030 with FEL hold, and how much does the B3030 with FEL and Kub BH75 hold?
/ Which backhoe for B3030? #8
The BH75 Kubota Backhoe and subframe comes with the proper hyd lines for the backhoe (they are not a hyd remote valve) The Woods Backhoes are designed as fit-alls, they do make a wonderful backhoe, but the fit to the tractor is not always the nicest for everyones taste. The BH75 in my opinion dismounts easier and fits much closer to the machine, you do hower need to remove the 3point parts for the Kubota Hoe. 3point mounted hoes are good provided you take the time to check your adjustments on a regular basis, if you don't you will break pieces. As far as pricing goes the two will be really close, but the Woods hoe will take longer to install
Hope this Helps
/ Which backhoe for B3030? #9
I assume you have a loader on your B3030. I agree with your dealer, even though Woods has the B3030 listed to install the BH80, I too think it's too big for the tractor. Also, go with the PTO pump, you'll be satisfied with the results. The pump puts out 6GPM and the tractor is rated @5.2 gpm. Doesn't seem that much, but the PTO pump is dedicated to the backhoe.
/ Which backhoe for B3030? #10
</font><font color="blue" class="small">( I assume you have a loader on your B3030. I agree with your dealer, even though Woods has the B3030 listed to install the BH80, I too think it's too big for the tractor. Also, go with the PTO pump, you'll be satisfied with the results. The pump puts out 6GPM and the tractor is rated @5.2 gpm. Doesn't seem that much, but the PTO pump is dedicated to the backhoe. )</font>
IMHO..100% correct all the way around.
I don't have a loader on my B3030, as I don't yet have a B3030. /forums/images/graemlins/smirk.gif I'm just trying to research everything as thoroughly as possible so that when I'm ready to pull the trigger, I'll know exactly what to order.
I am not even considering a 3pt mount backhoe, only a 4 point subframe, and from what I've seen of smaller Woods hoes, they add plenty of steel subframe to protect the machine from breakage.
As far as the PTO pump is concerned, you're really only getting another .8 gpm over what the B3030 pump is putting out, because the only thing you're putting all of that 5.2 gpm toward is the backhoe for 90-95% of backhoe use. At least that's the way I figure it.
However, based on some of the feedback, and some additional thoughts on my part, I don't think I can justify going with the Woods BH70X's smaller hoe just to get the thumb option, for $800 more than the BH75. To me, the only reason for going with a Woods hoe is to get the larger, more powerful 80, but since I'm getting more feedback all the way around that the 80 is too big for the B3030, I'm thinking it'd be more worth spending my money on a lightweight, removable FEL bucket grapple - I'd get a whole lot more use out of that.
The rear remote issue is not going to be a deciding factor on which backhoe, as I already know I need the remotes for, at the very least, a top-n-tilt.
/ Which backhoe for B3030? #12
</font><font color="blue" class="small">( The hydraulic feed is not standard with tractor, only when BH is installed...atleast that has been the case with the two Kubotas I've had (B7500, L2800). )</font>
As far as what Im told..thats 100% correct. The rear on my B3030 is blocked off with a plate..and if/when I buy a BH that operated from the tractor hyd's..then the hardware necessary to operate are included in the price of the backhoe...OR ( again..from what my dealer told me) I can add the hardware for $550 to use the tractor hyd's to run say a log splitter..etc..etc.
/ Which backhoe for B3030? #13
That's exactly what I figured as well so I just ordered a Tatro grapple for the bucket of my B7800. Now I have to figure out what remote valve kit to buy in order for it to work off my loader joystick. The WR Long ones are $600 complete.
/ Which backhoe for B3030? #14
Why would you change all the fluid every time you removed the hoe?I just bought the BH-75 for my B-7800 and will have it installed 4/16.No mention of changing fluid.My reason for preferring the seperate system would be that if you blow a line it could incapacitate the whole tractor
/ Which backhoe for B3030? #15
I've spoken with several dealers, including Neil @ Messicks, and they've all told me that even though the B3030 will handle the Woods BH80-X, they don't really recommend it for this tractor. The primary reason is that it's a pretty big hoe and can "toss" the tractor around a bit more than one might want...
For this reason, and the additional money for the Woods, I went with the BH75 with an aftermarket thumb - heck, I'm only giving up a few hundred pounds of digging force that I'll probably never notice anyway (3780 vs. 3339 at the bucket and 2480 vs. 2097 using the dipperstick). Additionally, unless I'm mistaken, the BH75 is a slightly more compact unit as well.
It sure is easy to get caught up in the numbers game isn't it???
/ Which backhoe for B3030? #16
I have the BH-75. I have removed and replaced it many times. In fact one day I wished I had two tractors because I removed it and replaced it four times. It is really not that hard to do. The fluid stays trapped in the backhoe and you just connect the supply and return lines together. If you broke a hose on the backhoe you could just connect these two lines together and bypass the hoe.
I am not sure what Sully means about changing the fluid. I have only changed mine at the 50 hour point so far.
/ Which backhoe for B3030? #17
Seeing that the B3030 and the B7800 are nearly the same in size and power, attached are a few photos of my B7800 with the Woods BH70X with thumb. I also included a photo showing the hydraulic hook-up. I had my dealer plumb a supply and a return from the hydraulic distribution manifold. When the BH is not in use I just connect the supply and the return so I don't "dead head" the line. The Kubota pump supplies plenty of hydraulic power for the BH, I don't see a need to use the PTO and power a separate pump.
Secondly, I looked at the BH80X but it was too large for the B7800, if I was going to primarily dig with the tractor I would not have gone with the B7800, but something larger like the L series Kubota, or a Case tractor, they are heavier than the B series which as a benefit helps make them more stable when digging.
Lastly, for my application I went with a 12" bucket as well.
Just my comments from when I did my due diligence when I was shopping for a BH.
Dennis Bialecki
/ Which backhoe for B3030? #18
bialecki said:
. I also included a photo showing the hydraulic hook-up. .....
Dennis Bialecki
I am also considering a BH70X for my B7800. I was told that the 3pt hitch lift arms had to be removed to install the BH, but in your photo it appears that they are still in place.Does this work out O.K.? Or am I seeing something that's not there?
Thanks
/ Which backhoe for B3030? #19
Thanks
There seems to be a lot of room beneath the plateform to leave the hitch mounted. IMHO, you have to be careful not to use the hitch while the backhoe is mounted. But it has a plus: no hassle about put/remove the hitch.
Is it me or the pieces of the Woods main frame is... bolted? (third picture) Since it's not welded, one must not forget to check the torque of those bolts from time to time. Nevertheless, Woods make nice backhoes.
/ Which backhoe for B3030? #20
Thanks
Nope, just be careful not to lift them too high when the BH is installed. You are physically on the BH seat so to reach around and lift the 3 pt hitch is not practical, so you can leave them on during hookup, operation of the BH and removal of the BH.
The heavy mainframe is bolted to the tractor all the way up to the FEL's mainframe. The torque to mount the bolts is high, however occasionally it probably is wise to check the torque, but no different than checking the FEL's mainframe's securement. The ease of mounting and unmounting the Woods BH is very easy, a large 1-1/2" bolt on each top side of the frame. Also you can see in Photo #1, I did leave the towing hitch in place as well, could have easily removed it, but I would probably misplace it somewheres in my garage, or cellar.
In general I am very happy with the quality (tolerances are very good), ease of use and efficacy of the Woods BH.
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2015 C.GALLEGOS PNEUMATIC TRAILER (A60736)
2015 C.GALLEGOS...
44052 (A55852)
44052 (A55852)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
