Where to buy a swinging drawbar?
   / Where to buy a swinging drawbar? #1
jshwhite
Missouri
Kubota L4740, Massey 65, Case 580C
Does anyone know a source for a good heavy swinging drawbar? My 3710 didn't come with one. I bought one at TSC and found it to be junk - bent and then broke within a few weeks of hauling trailer loads of firewood. To haul the trailer I designed and built a hitch that goes on the 3pt, but now I'm getting into haying and I need a swinging drawbar for pulling implements. Any suggestions? Thanks!
   / Where to buy a swinging drawbar? #2
That's a tough one, because I think most are made the same...maybe try your dealer. You might pay a premium price for it, but you'll have it quick. I read a thread on this a few days ago, and one was ordered from the net. Let me see if I can find that thread.
   / Where to buy a swinging drawbar? #3
Just got called in to work, I'll try again later...
   / Where to buy a swinging drawbar? #4
I think youre referring to the fixed drawbar. ... fixed in up/down height vs adjustable height like on on the 3pt. The one meant for your tractor should be adequate. Aftermarket general utility items can be a real crap shoot.
larr
Let me know what you find - I'd be interested. Thanks!
larr
Yes, I am referring to the fixed drawbar. I'm hoping to avoid getting the one for the tractor from Kubota because they like to charge lots of money for them :D As I mentioned, the aftermarket one from TSC was junk, so I'm hoping to find some other aftermarket one that isn't junk. Maybe there is no such thing? :)
   / Where to buy a swinging drawbar? #6
That's the most likely answer. AgriSupply carries them (or used to), but I doubt it's any better quality than TSC. If there's a Kubota boneyard within economical driving distance, a take-off is one possibility. But if you charge yourself by the hour for searching and driving time, I think you'll probably do better just biting the bullet and get one from a dealer.
//greg//
Stopped by the dealer today. A new drawbar is $145. I said no thank you :D
Anyone ever made one? I can get steel really cheap in my area. Probably wouldn't cost $10 for a chunk of steel for it. Thoughts? Ideas? Suggestions?
   / Where to buy a swinging drawbar? #8
Yes. You already saw what happened with the TSC steel. It will cost more than you think to buy the right steel. Probably AR400 wood be good because it is hi strength and surface hardened. After you buy it tho, you then have to cut it and drill it or pay to have it done. It will be very difficult to drill the large holes you need thru that fairly hard steel. You need a slow turning drill press and a big expensive drill bit. Buy the Kubota part unless you are a skilled fabricator. Its guaranteed to work.
larry
   / Where to buy a swinging drawbar? #10
Wow, $145 is cheap - all the names like to charge a lot for an item like that.
Unfortunately, you will not find a good one in aftermarket.
Have a look at the junk yards, there are some that specialize in smaller or Kubota tractors, can get a better price on a used one, otherwise back to the dealer.
--->Paul
   / Where to buy a swinging drawbar? #11
Have you thought of using a standard straight drawbar between your lift arms?
A lot cheaper and they are quite versatile:tractor:.
   / Where to buy a swinging drawbar? #12
I have a Kubota drawbar I could part with, but not sure if that is the one you are looking for. It is a straight piece of steel and it measures 26.5"x2"x1.25". There are 7 or 8 holes in it. If this is what you are looking for send me a PM. It is not the kind that attaches to the 3pt hitch but the one that mounts under the transmission/3pt hitch housing. I believe it is used on the GL models but not sure
Can these be used with pto-driven implements? I considered one of these, but didn't think it would work with a pto implement.
   / Where to buy a swinging drawbar? #14
Like towing a hay baler? Yes, but only if you ensure the lower lift arm distance from the ground remains well below the level of the PTO shaft. But that can be problematic in hilly terrain. I personally would feel more comfortable with the swinging drawbar like you originally proposed.
I've never owned a tractor without one. How'd yours end up missing?
//greg//
//greg//
That's what I was thinking - glad to hear you agree.
How did it end up missing? We bought it used, so maybe the previous owner "borrowed" it :) Not sure, but I do wish I had it now!
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2020 Chevrolet Silverado 1500 Pickup Truck (A59230)
2020 Chevrolet...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
2020 JOHN DEERE GATOR SUV590M S4 UTV (A60430)
2020 JOHN DEERE...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
