Where to buy a swinging drawbar?
   / Where to buy a swinging drawbar? #1
jshwhite
Gold Member
Missouri
Kubota L4740, Massey 65, Case 580C
Does anyone know a source for a good heavy swinging drawbar? My 3710 didn't come with one. I bought one at TSC and found it to be junk - bent and then broke within a few weeks of hauling trailer loads of firewood. To haul the trailer I designed and built a hitch that goes on the 3pt, but now I'm getting into haying and I need a swinging drawbar for pulling implements. Any suggestions? Thanks!
   / Where to buy a swinging drawbar? #2
That's a tough one, because I think most are made the same...maybe try your dealer. You might pay a premium price for it, but you'll have it quick. I read a thread on this a few days ago, and one was ordered from the net. Let me see if I can find that thread.
   / Where to buy a swinging drawbar? #3
Just got called in to work, I'll try again later...
   / Where to buy a swinging drawbar? #4
I think youre referring to the fixed drawbar. ... fixed in up/down height vs adjustable height like on on the 3pt. The one meant for your tractor should be adequate. Aftermarket general utility items can be a real crap shoot.
larr
Let me know what you find - I'd be interested. Thanks!
larr
Yes, I am referring to the fixed drawbar. I'm hoping to avoid getting the one for the tractor from Kubota because they like to charge lots of money for them :D As I mentioned, the aftermarket one from TSC was junk, so I'm hoping to find some other aftermarket one that isn't junk. Maybe there is no such thing? :)
   / Where to buy a swinging drawbar? #6
That's the most likely answer. AgriSupply carries them (or used to), but I doubt it's any better quality than TSC. If there's a Kubota boneyard within economical driving distance, a take-off is one possibility. But if you charge yourself by the hour for searching and driving time, I think you'll probably do better just biting the bullet and get one from a dealer.
//greg//
Stopped by the dealer today. A new drawbar is $145. I said no thank you :D
Anyone ever made one? I can get steel really cheap in my area. Probably wouldn't cost $10 for a chunk of steel for it. Thoughts? Ideas? Suggestions?
   / Where to buy a swinging drawbar? #8
Yes. You already saw what happened with the TSC steel. It will cost more than you think to buy the right steel. Probably AR400 wood be good because it is hi strength and surface hardened. After you buy it tho, you then have to cut it and drill it or pay to have it done. It will be very difficult to drill the large holes you need thru that fairly hard steel. You need a slow turning drill press and a big expensive drill bit. Buy the Kubota part unless you are a skilled fabricator. Its guaranteed to work.
larry
   / Where to buy a swinging drawbar? #10
Wow, $145 is cheap - all the names like to charge a lot for an item like that.
Unfortunately, you will not find a good one in aftermarket.
Have a look at the junk yards, there are some that specialize in smaller or Kubota tractors, can get a better price on a used one, otherwise back to the dealer.
--->Paul
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2003 Big Tex 10PI...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
