When one door closes, another opens....
/ When one door closes, another opens.... #71
Carl recommended those tachs and I have been reasonably happy with mine.
Ken
Ken
Good to hear some firsthand experience! :thumbsup:
Note that rather than a Power Trac ID plate, this oldie has a CLA plate -- with a serial number of 123....
/ When one door closes, another opens.... #73
Excellent!
/ When one door closes, another opens.... #74
Kent is the Tachometer pretty accurate? Would like to put one on my 422.
No real way to tell how accurate it is, since there are no true electronic signals on a diesel such as spark in a spark plug wire. Some alternators have a signal that can be converted to RPM, often with an external adjustment "box," and calibration is always required.
That said, I've used a Tiny Tach on a garden tractor before and was satisfied with it... the readout can be "jittery" for a couple seconds after you change the throttle, but then it stabilizes. My biggest complaint is that they use a sealed-in battery to maintain the hours accumulated, so they only last 5-7 years or so.
/ When one door closes, another opens.... #76
The newer ones have memory that does not require a battery to maintain so they run off of your tractor's electrical system. Yes, my older internal battery one only lasted 3 or 4 years.
Ken
/ When one door closes, another opens.... #79
CLA is the parent company and predecessor to Power-Trac. Same address.
CLA Industrial Equipment & SuppliesTazewell Industrial Park, Tazewell, Virginia
All the best,
Peter
429970 (A61165)
429970 (A61165)
2020 DRAGON ESP...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
Giyi GY-SF60 (A60463)
43023 (A59228)
43023 (A59228)
2011 Caterpillar 304DCR (A60462)
2011 Caterpillar...
