Wheeled excavator ???
/ Wheeled excavator ??? #23
Most wheeled excavators use two differentials connected to a transfer case in the center. The hydraulic motor is then attached to this case to provide the power to the axles. Typically, both axles have steering.
/ Wheeled excavator ??? #24
Don’t want to be a bummer but I don’t think there is anyway you actually get a 3.8t machine for 6k usd. I bet once you start the process that 6k is for the common 1.6t tracked machine and they can get you the 3.8 but for more $.
/ Wheeled excavator ??? #25
I completely agree, I’d be extremely skeptical
/ Wheeled excavator ??? #27
Having had wheeled and tracked excavators (2 to 11 tonnes) - if you need to go off-road, you need tracks. If it's hilly, you need tracks. Wheeled ones are *wonderful* for doing little jobs all around the place, but you must have a decent surface to work from (stone/paved, flat). The slightest incline can be terrifying.
Many wheeled diggers don't have true 4x4, so get stuck easily. I've done it. Tracked diggers will slowly make a mess of your stone/gravel areas, whenever you turn. But you probably won't ever get stuck.
Stability is definitely definitely better with tracked diggers. They are much easier to use; fewer buttons, less wobble/inertia, greater safe lifting capacity. For digging, you'll always have the dozer down and ideally some struts; whereas with a tracked machine you often don't need to.
I can see a market for a small 3-5 tonne wheeled excavator to have as a backup to a bigger tracked digger.
(OP, that Aliexpress link seems to go to an "assistant device" - clicking the more-likely model name doubles the price).
Another Wile E, Coyote idea gone south
/ Wheeled excavator ??? #29
Don’t give up your dreams, I wanted an excavator for years, finally got a baby one last summer. I sure wish my mini had a better ground speed, that being said I really love having it around. I just have to trailer it if the days task isn’t close to home. Today I used it at our pond, I added a ball to the tractors draw bar so I could have both machines to work together.
/ Wheeled excavator ??? #30
View attachment 2888990 View attachment 2889008
What’s hanging in the picture behind the mini?
/ Wheeled excavator ??? #31
I made a counterweight/implement holder based on a 2” hitch/receiver. Holds the ripper, 8”,30” buckets, and rake.
It’s easy to remove for tighter working areas, but I rarely need to take it off. Added about 220lbs, which makes a difference on these mini’s for moving around heavy things with the bucket/thumb.
/ Wheeled excavator ??? #32
That’s what I thought I was looking at. An 8” bucket - ok, a 30” isn’t too heavy to pick by hand? Actually really nice that you can carry everything with (y).
/ Wheeled excavator ??? #33
The 30” is a bit heavy, but I can pick it up and change it out.
I did also get the “quick attach coupler” some don’t care for it but I like it. I have only used the quick attach, I installed it when I first got the mini, just seems easier than always changing pins, so far I mainly use the 8” and the 16”, pretty much defer to the tractor if I really want to move some material.
  • Good Post
Reactions: D&D
/ Wheeled excavator ??? #34
Wheeled excavators can be quickly transferred,
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64556)
Tropic Trailer...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
POLY WATERING TROUGH & SUCTION HOSE (A64278)
POLY WATERING...
3PT SPRAYER RACK (A64278)
3PT SPRAYER RACK...
2022 EZ-GO ELITE...
(UNUSED) JOHN DEERE RC10R ROTARY MOWER (A64278)
(UNUSED) JOHN...
