Wheeled excavator ???
/ Wheeled excavator ??? #23
Most wheeled excavators use two differentials connected to a transfer case in the center. The hydraulic motor is then attached to this case to provide the power to the axles. Typically, both axles have steering.
/ Wheeled excavator ??? #24
Don’t want to be a bummer but I don’t think there is anyway you actually get a 3.8t machine for 6k usd. I bet once you start the process that 6k is for the common 1.6t tracked machine and they can get you the 3.8 but for more $.
/ Wheeled excavator ??? #25
I completely agree, I’d be extremely skeptical
/ Wheeled excavator ??? #27
Having had wheeled and tracked excavators (2 to 11 tonnes) - if you need to go off-road, you need tracks. If it's hilly, you need tracks. Wheeled ones are *wonderful* for doing little jobs all around the place, but you must have a decent surface to work from (stone/paved, flat). The slightest incline can be terrifying.
Many wheeled diggers don't have true 4x4, so get stuck easily. I've done it. Tracked diggers will slowly make a mess of your stone/gravel areas, whenever you turn. But you probably won't ever get stuck.
Stability is definitely definitely better with tracked diggers. They are much easier to use; fewer buttons, less wobble/inertia, greater safe lifting capacity. For digging, you'll always have the dozer down and ideally some struts; whereas with a tracked machine you often don't need to.
I can see a market for a small 3-5 tonne wheeled excavator to have as a backup to a bigger tracked digger.
(OP, that Aliexpress link seems to go to an "assistant device" - clicking the more-likely model name doubles the price).
Another Wile E, Coyote idea gone south
/ Wheeled excavator ??? #29
Don’t give up your dreams, I wanted an excavator for years, finally got a baby one last summer. I sure wish my mini had a better ground speed, that being said I really love having it around. I just have to trailer it if the days task isn’t close to home. Today I used it at our pond, I added a ball to the tractors draw bar so I could have both machines to work together.
/ Wheeled excavator ??? #30
View attachment 2888990 View attachment 2889008
What’s hanging in the picture behind the mini?
/ Wheeled excavator ??? #31
I made a counterweight/implement holder based on a 2” hitch/receiver. Holds the ripper, 8”,30” buckets, and rake.
It’s easy to remove for tighter working areas, but I rarely need to take it off. Added about 220lbs, which makes a difference on these mini’s for moving around heavy things with the bucket/thumb.
/ Wheeled excavator ??? #32
That’s what I thought I was looking at. An 8” bucket - ok, a 30” isn’t too heavy to pick by hand? Actually really nice that you can carry everything with (y).
/ Wheeled excavator ??? #33
The 30” is a bit heavy, but I can pick it up and change it out.
I did also get the “quick attach coupler” some don’t care for it but I like it. I have only used the quick attach, I installed it when I first got the mini, just seems easier than always changing pins, so far I mainly use the 8” and the 16”, pretty much defer to the tractor if I really want to move some material.
  • Good Post
Reactions: D&D
/ Wheeled excavator ??? #34
Wheeled excavators can be quickly transferred,
JOHN DEERE 1770NT - 12R30" VACUUM PLANTER (A64278)
JOHN DEERE 1770NT...
(INOP) INTERNATIONAL 1066 TRACTOR (A64278)
(INOP)...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
